Help with ecm replacement
Old Nov 18, 2025 | 04:05 PM
RattyC4's Avatar
RattyC4
Default Help with ecm replacement
I sent my ecm off for repair, got it back in worse condition, and now Cardone says it was not repairable in the first place.
The ENL Flash 2 ECM is out of stock everywhere i can find it, and I need to get this car running. (1984 model year) Is there another ecm that I can get that could be programmed to run the crossfire, or would I need to do a full intake swap for an aftermarket EFI system, or a carburetor?
Old Nov 18, 2025 | 04:53 PM
flannel_man's Avatar
flannel_man
Cruise-In VI Veteran
EBL Flash ii used to be the go to in your shoes. Issues after the owner died last year.
Cross-fire performance
Is working on trying to buy that company and breathe life back into it, but apparently the owner's family thinks they are sitting on a massive diamond mine and want a Powerball level ransom for it vs them just leaving it to rot and be a distant memory for all TBI and TPI Chevy users
Check ebay and marketplace for an ECM. Craigslist if you're feeling lucky. Sometimes you'll see an EBL in the for sale section here but they go fast. Be prepared to pay 4 or $500 for either solution though. Glad I bit the bullet for EBL when I did
