Mystery
Old Dec 14, 2025 | 04:46 PM
Danny logan's Avatar
Danny logan
1st Gear
Default Mystery
My 94 Corvette runs great for about 40 minutes then starts misfiring badly almost like limp mode , turns over for long time before it will restart, let sit for few hours will start right up and run great for approximately 40 min then acts up again,have replaced fuel pump,coil, ignition module and distributor assembly which was a cheapo ,any suggestions would be great
Old Dec 14, 2025 | 10:55 PM
s carter's Avatar
s carter
You hit pretty much all normal problems, so here's some other possible, something is heat soaking.
When it acts does it seem to be running but just Gutless (Catalytic converter) or heat soaking fuel rail or Vapor lock in the tank.
Old Dec 16, 2025 | 08:22 PM
JD1964's Avatar
JD1964
Have you put a fuel pressure gauge on it during a time it’s acting up? Have you replaced the fuel filter?
To Mystery
