84-88 c4 window position
Old Dec 21, 2025 | 09:05 PM
johnfin's Avatar
johnfin
Default 84-88 c4 window position
When the window is all the way down should you be able to see glass. Mine sticks up 1" above rubber wiper.
Old Dec 21, 2025 | 09:29 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
no...
Old Dec 21, 2025 | 10:01 PM
s carter's Avatar
s carter
Flush or a little below
Old Dec 24, 2025 | 11:11 AM
johnfin's Avatar
johnfin
Where is the adjustment to get the window lower?
Old Dec 24, 2025 | 02:10 PM
s carter's Avatar
s carter
Behind the panel (expected) but you can Jockey the glass into place and loose the mount bolts and the mount will probably slide to a better position. Also look inside the door to see if anything is laying in the bottom of the door. I got a very nice electric screwdriver
There also might be a stop in the door in the later car. But most just settle onto a rubber pad
To 84-88 c4 window position
