Quad Driver
Old Feb 19, 2003 | 05:18 PM
FSTRNU's Avatar
FSTRNU
Default Quad Driver
I removed some emissions parts today and now have a quad driver fail which I thought that I might have a fail but I didnt think a whole quad driver would fail. While I was watching the computer I noticed a driver 1 fail with a code and a driver 2 intermittent fail with no code it only failed at idle not at cruising speed. Is there a problem with the ECM as far as driver 2? Would anyone being willing to trade a chip that will remove the emissions stuff for some cash? :cheers:
Old Feb 19, 2003 | 06:33 PM
ZylaRace's Avatar
ZylaRace
Default Re: Quad Driver (FSTRNU)
Not sure what you are asking,.....
Then talking about the Quad Driver, usually people are talking about a part inside the ECM. This is the electronic switch that turns on a relay (typically).
Old Feb 19, 2003 | 07:47 PM
FSTRNU's Avatar
FSTRNU
Sorry I am use to airplane electronics and our things we call quad drivers in the computers usually control more than one thing which probably isnt the same thing but the same name. I think if I just get a chip that will turn off the egr stuff i will be set
Old Feb 20, 2003 | 09:50 AM
ZylaRace's Avatar
ZylaRace
Turning off the EGR in a 165 ECM, only entails turning off the error flag. i.e. No "engine" light, no code.
Sounds to me that is what you are looking for. It is very easily done w/ programming equipment.
Old Feb 20, 2003 | 01:13 PM
HighHopes85's Avatar
HighHopes85
Default Re: Quad Driver (ZylaRace)
To effectivelydisable EGR, I believe you also need to set minimum EGR enable temp w/r to MAT to the highest possible number - 1. Just covering up the flag still allows the engine to think the EGR is hooked up...and will still use whatever logic it uses when EGR is supposed to be functioning. Good luck, -Matt
[Modified by HighHopes85, 12:14 PM 2/20/2003]
To Quad Driver
