Shift Kit/Torque Converter?????
Old Feb 19, 2003 | 07:02 PM
Newbie85
Default Shift Kit/Torque Converter?????
My tranny is coming out to fix a leak at the pump, I figured it would be a good time to do the torque converter and a shift kit. Unfortunately I know absolutely nothing about either. :nonod:
What would you recommend/why? Or am I better off not doing one/both?
(Its a 96 auto, 100% stock)
Old Feb 19, 2003 | 07:48 PM
RadPolo96's Avatar
RadPolo96
Default Re: Shift Kit/Torque Converter????? (Newbie85)
Do you plan on changing the gears in the future as well? I put in a Yank stealth 2800 stall converter. Later I added my gears. Both added alot of acceleration to the car. I wouldnt go any higher than 3000 if its a daily driver like mine. Its probably also a good idea to get a larger tranny cooler as well, they are fairly cheap and extend the life of your tranny...especially if you add a higher stall. The higher the stall the more heat you will be generating and the more wear there will be.
[Modified by RadPolo96, 6:51 PM 2/19/2003]
Old Feb 19, 2003 | 07:55 PM
Newbie85
Default Re: Shift Kit/Torque Converter????? (RadPolo96)
I've got 3.07 now, more than likely I will change within the next 6-12 months...
[Modified by Newbie85, 6:56 PM 2/19/2003]
Old Feb 20, 2003 | 05:40 AM
Probuilt's Avatar
Probuilt
I would install a Trans-Go Performance Shift kit (modified), along with a 9.5" torque converter with a 2,400-2,500 stall (with a high STR) and this way you can "keep" the 3.07's in back for better gas mileage, lower noise, lower cruise rpm, etc.
Old Feb 20, 2003 | 06:53 AM
Mini_K's Avatar
Mini_K
Default Re: Shift Kit/Torque Converter????? (Probuilt)
go with a Precision Industries Vigalante convertor, they are the best convertor out there :D and extremely well built with 1 free adjustment. they are built to suit your application. :D
[Modified by Mini_K, 11:54 AM 2/20/2003]
Old Feb 20, 2003 | 08:43 AM
HeeHaw89's Avatar
HeeHaw89
Default Re: Shift Kit/Torque Converter????? (Mini_K)
I'm using a 2600 Vigilante and it is working great. I am also running a cooler as well. No shift kit yet, still the stock 116k transmission. I figured I'd wait until it needs to be pulled and replaced before doing that. I find the 2600 is working well with my 3.07 rear too.
Old Feb 20, 2003 | 02:57 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
A little higher TC (I have 2,000rpm) will allow a stronger launch but feel the same under normal driving; a shift kit will chirp the tires on a heavy throttle 1-2 shift and feel only a little firmer under normal driving.
Since I like the agressive feel I recommend both upgrades.
Old Feb 20, 2003 | 04:29 PM
Phil-tha-Rush's Avatar
Phil-tha-Rush
I agree.
I think the TC is a great 1st mod.
I have a 2600 Vigalante with 373 gears and love it.
I agree with earlier comments that the TC will wake up your 3.07 gears. You will LOVE it.
With a TC you DO want either a shift kit, or a Hyperteck Power Programmer to "firm" up the shifts.
enjoy :cheers:
Old Feb 20, 2003 | 04:53 PM
korvettek's Avatar
korvettek
Default Re: Shift Kit/Torque Converter????? (Phil-tha-Rush)
im sold im sold-now a couple of questions.do the shift kit make half shafts u joints life short lived.question #2 a 2600 vigilante TC will it lock up at 1800 when you are cruising in 4th gear or do it even lock up. :yesnod:
Old Feb 20, 2003 | 05:33 PM
Newbie85
Default Re: Shift Kit/Torque Converter????? (korvettek)
Out of curiosity, what is the stock stall on a 96 auto?
Old Feb 20, 2003 | 05:37 PM
Phil-tha-Rush
here is a link that might help
http://www.converter.com/vigilante.htm
I am by NO means an expert, and dont know the specifics of lockup, but you DO want a locking coverter for sure.
When I 'power brake"... the rpm does not go to 2600, but goes to about 1200.
Of course.... anytime I am "under" 2600 rpm and mash the pedal, it will "Flash" to 2600.
Drivability is not an issue with the Vig 2600, but with a completely stock engine, I wouldnt go with more than a 2800 rpm converter.
Notice on the link that Vig NOW offers a 2 year FREE rebuild, so if you arent happy with what you buy, you get 1 free rebuild. :D
Old Feb 20, 2003 | 08:23 PM
red-y's Avatar
red-y
The TQ lock up can be adjusted in 4th gear depending on your model either with a programer or chip. On mine it will lock up at 2800 then in fourth gear it locks up around 35-38 mph. I agree with the posts these are great modifications particularly when you add gears.
BAM.. :steering:
Old Feb 21, 2003 | 12:45 AM
korvettek's Avatar
korvettek
ok ou can sell me your 307 then .lol
Old Feb 21, 2003 | 12:47 AM
korvettek's Avatar
korvettek
whats str mean
To Shift Kit/Torque Converter?????
