cast steel vs forged
Only problem is that its twice the price in some cases.
It really depends on what youre going with on the motor whether you really NEED to have forged internals.
NA power 4-500HP, cast 'should' last no problem.
Power Adder 4-500HP, cast will not last long.. (NOS/Super/Turbo)
Forged parts are, just as the name implies, harder treated metals.
The reason I ask is because pretty soon here I am going to be building a street motor. I will be running 100 shot of nitrous on it but not alot. Only when i find my way down to the track. The motor should make between 430-450 hp. (not at the wheels) So forged pistions are a must but I am not sure between a scat 9000 series cast steel crank or going forged... I guess I just can't decide if the cost difference will be worth it, especially since nitrous will not be used very often..
[Modified by 85vettelovin, 9:54 PM 2/19/2003]
[Modified by 85vettelovin, 10:00 PM 2/19/2003]
Forging means taking a hot, plastic, malleable piece of stock, and placing it into a form, and then subjecting it to extreme pressure until it assumes the shape of the form. Little or no porosity, unidirectional grain, plastic stress and strain added to the structure, harder surface, etc.
Also, it's not just RPMs that hurt cranks, it's harmonics, which are a function of frequency (RPM) and amplitude (HP). The crank doesn't know that there's nitrous on the motor, it just knows the load that's transmitted to it through the rods.
Long and short, my opinion on the deal is that if you're going to build a motor that you plan on beating on, I'd put forged in it and be done (tighter quality control, stronger material, lighter cranks, stiffer cranks, easier to obtain necessary bearing clearances, etc, etc). If you're going to build a motor that's not going to be pounded, cast is fine as clearances aren't as critical, loads won't be as high, etc, etc.
Cast = not so relaiable on a street racer as cast. Nothing to it.
Build what you can afford. If you can afford, get forged internals, as it won't hurt anything, but will outlast any cast parts down the line, that's for sure.
:auto:
What do you or anyone else think? I'm curious cuz i'm moving in this direction
Kitt
Here is a real specific question, you mention power adders like a SC. If i put a SC on mine it looks like I'll be sitting around 430 ish at the RW. Are you saying that the internals will not last long under these conditions with normal driving, semi monthly quarter mile runs, and occasional getting all over it?
THE CRANK AND RODS DON'T KNOW IF THE ENGINE'S FORCED INDUCTION OR NOT!!! THEY KNOW POWER!!!
Now, if you're looking at pistons, that's another story due to the heat that is transferred to the pistons from non-intercooled systems, but as long as there's enough oil on the wrist pins, the rods STILL won't know if there's a power adder or not (I've seen wrist pins with insufficient oiling blue the ends of some high $$$$ rods within 10 minutes on an engine dyno).
To anwer your question Kit, I'd be a little leary of trying to go for that much power on a stock cast crank if the motor will be abused. It's not that the crank will break and send pieces and parts flying out of the bottom of the motor or anything, you will just wear out the internals faster and need a rebuild sooner. To give you an idea of what I mean, my car which made 228 rwhp on it's last dyno pulls (two years ago) only got 60k miles out of the motor before it needed a rebuild (rings were toast, the main bearings were solid copper, and the crank was wobbling so badly from the excessive bearing clearance that I couldn't get a front seal or a 1-piece rear main to live for more than ~6 months before they needed replacement). You're talking about doubling that power (at the wheels) with the same internals. The motor just simply won't last that long. I'm a big proponent of the theory that if you want to build a sporty, strong motor then do it all the way. If you want a stock motor, build a stock motor. I'm in the middle of rebuilding my motor right now, and because I'm a broke (graduate student), I'm going back stock. I'm saving up money, however, to build a motor over the summer with a Cola superlight crank, Oliver rods, JE pistons, etc, etc. I KNOW my current motor won't last very long the way it's treated (run harder than you intend, but also at a lower power level), so I'm already planning for the motor that I will build that I know will last much longer.
i'm looking around 500hp NA and 200+ shots of nitrous on a bolt main.
many engine builders havee told me scat 9000.
The scat 900 is more than enough, especially with nitrous-
you probobly wont be reving that high.
I know i'm going 65-6700rpms NA and 6200 with the bottle.
:party:
id get forged pistons and good rods, but you honestly have no need for a forged crank with a 100hp shot.
there is a rotating assembly GP for scat and callies i think on camaroz28.com
check it out :cool: :cheers:
good luck
just make sure its properly balanced and the clearances/tq specs are good more than anything
[Modified by TreyZ28, 3:59 PM 2/20/2003]
Kitt
I honestly don't know where this distinction between "power adder HP and non-power adder HP" comes from....it's all crap.
but what do i know.
I'm an NA guy
i'm a parrot when it comes to FI :cheers:
bah, just take out a big loan and get a full billet bottom end :lolg:
i have billet rods-
its nice knowing my rods wont stretch (although my crank may explode, my rear is a ticking timebomb and the Trans... lets just pray)
[Modified by TreyZ28, 4:16 PM 2/20/2003]
