[Octane] Tuning parameter affects
Old Feb 20, 2003 | 09:37 AM
Tonys96's Avatar
Tonys96
Default [Octane] Tuning parameter affects
Compression Ratio
Most people know that an increase in Compression Ratio will require an increase in fuel octane for the same engine design. Increasing the compression ratio increases the theoretical thermodynamic efficiency of an engine according to the standard equation
Efficiency = 1 - (1/compression ratio)^gamma-1
where gamma = ratio of specific heats at constant pressure and constant volume of the working fluid ( for most purposes air is the working fluid, and is treated as an ideal gas ). There are indications that thermal efficiency reaches a maximum at a compression ratio of about 17:1.
The efficiency gains are best when the engine is at incipient knock, that's why knock sensors ( actually vibration sensors ) are used. Low compression ratio engines are less efficient because they can not deliver as much of the ideal combustion power to the flywheel. For a typical carburetted engine, without engine management:
Compression Octane Number Brake Thermal Efficiency
Ratio Requirement ( Full Throttle )
5:1 72 -
6:1 81 25 %
7:1 87 28 %
8:1 92 30 %
9:1 96 32 %
10:1 100 33 %
11:1 104 34 %
12:1 108 35 %
Modern engines have improved significantly on this, and the changing fuel specifications and engine design should see more improvements, but significant gains may have to await improved engine materials and fuels.
Air:Fuel Ratio
Traditionally, the greatest tendency to knock was near 13.5:1 air-fuel ratio, but was very engine specific. Modern engines, with engine management systems, now have their maximum octane requirement near to 14.5:1. For a given engine using gasoline, the relationship between thermal efficiency, air-fuel ratio, and power is complex. Stoichiometric combustion ( air-fuel ratio = 14.7:1 for a typical non-oxygenated gasoline ) is neither maximum power - which occurs around air-fuel 12-13:1 (Rich), nor maximum thermal efficiency - which occurs around air-fuel 16-18:1 (Lean). The air-fuel ratio is controlled at part throttle by a closed loop system using the oxygen sensor in the exhaust. Conventionally, enrichment for maximum power air-fuel ratio is used during full throttle operation to reduce knocking while providing better driveability. An average increase of 2 (R+M)/2 ON is required for each 1.0 increase (leaning) of the air-fuel ratio. If the mixture is weakened, the flame speed is reduced, consequently less heat is converted to mechanical energy, leaving heat in the cylinder walls and head, potentially inducing knock. It is possible to weaken the mixture sufficiently that the flame is still present when the inlet valve opens again, resulting in backfiring.
Timing
The tendency to knock increases as spark advance is increased. For an engine with recommended 6 degrees BTDC ( Before Top Dead Centre ) timing and 93 octane fuel, retarding the spark 4 degrees lowers the octane requirement to 91, whereas advancing it 8 degrees requires 96 octane fuel. It should be noted this requirement depends on engine design. If you advance the spark, the flame front starts earlier, and the end gases start forming earlier in the cycle, providing more time for the autoigniting species to form before the piston reaches the optimum position for power delivery, as determined by the normal flame front propagation. It becomes a race between the flame front and decomposition of the increasingly-squashed end gases. High octane fuels produce end gases that take longer to autoignite, so the good flame front reaches and consumes them properly.
The ignition advance map is partly determined by the fuel the engine is intended to use. The timing of the spark is advanced sufficiently to ensure that the fuel-air mixture burns in such a way that maximum pressure of the burning charge is about 15-20 degree after TDC. Knock will occur before this point, usually in the late compression - early power stroke period. The engine management system uses ignition timing as one of the major variables that is adjusted if knock is detected. If very low octane fuels are used ( several octane numbers below the vehicle's requirement at optimal settings ), both performance and fuel economy will decrease.
The actual Octane Number Requirement depends on the engine design, but for some 1978 vehicles using standard fuels, the following (R+M)/2 Octane Requirements were measured. "Standard" is the recommended ignition timing for the engine, probably a few degrees BTDC.
Basic Ignition Timing
Vehicle Retarded 5 degrees Standard Advanced 5 degrees
A 88 91 93
B 86 90.5 94.5
C 85.5 88 90
D 84 87.5 91
E 82.5 87 90
The actual ignition timing to achieve the maximum pressure from normal combustion of gasoline will depend mainly on the speed of the engine and the flame propagation rates in the engine. Knock increases the rate of the pressure rise, thus superimposing additional pressure on the normal combustion pressure rise. The knock actually rapidly resonates around the chamber, creating a series of abnormal sharp spikes on the pressure diagram. The normal flame speed is fairly consistent for most gasoline HCs, regardless of octane rating, but the flame speed is affected by stoichiometry. Note that the flame speeds in this FAQ are not the actual engine flame speeds. A 12:1 CR gasoline engine at 1500 rpm would have a flame speed of about 16.5 m/s, and a similar hydrogen engine yields 48.3 m/s, but such engine flame speeds are also very dependent on stoichiometry.
Temperature and Load
Increasing the engine temperature, particularly the air-fuel charge temperature, increases the tendency to knock. The Sensitivity of a fuel can indicate how it is affected by charge temperature variations. Increasing load increases both the engine temperature, and the end-gas pressure, thus the likelihood of knock increases as load increases. Increasing the water jacket temperature from 71C to 82C, increases the (R+M)/2 ONR by two.
Engine Speed
Faster engine speed means there is less time for the pre-flame reactions in the end gases to occur, thus reducing the tendency to knock. On engines with management systems, the ignition timing may be advanced with engine speed and load, to obtain optimum efficiency at incipient knock. In such cases, both high and low engines speeds may be critical. An interesting note on this comes from F1. They report that at engine speeds upward of 17,000 RPM octane requirements fall steadily.
Ambient Air Temperature
An increase in ambient air temperature of 5.6C increases the octane requirement of an engine by 0.44 - 0.54 MON. When the combined effects of air temperature and humidity are considered, it is often possible to use one octane grade in summer, and use a lower octane rating in winter. The Motor octane rating has a higher charge temperature, and increasing charge temperature increases the tendency to knock, so fuels with low Sensitivity ( the difference between RON and MON numbers ) are less affected by air temperature.
Altitude
The effect of increasing altitude may be nonlinear, with one study reporting a decrease of the octane requirement of 1.4 RON/300m from sea level to 1800m and 2.5 RON/300m from 1800m to 3600m [27]. Other studies report the octane number requirement decreased by 1.0 - 1.9 RON/300m without specifying altitude. Modern engine management systems can accommodate this adjustment, and in some recent studies, the octane number requirement was reduced by 0.2 - 0.5 (R+M)/2 per 300m increase in altitude. The larger reduction on older engines was due to:
„h Reduced air density provides lower combustion temperature and pressure.
„h Fuel is metered according to air volume, consequently as density decreases the stoichiometry moves to rich, with a lower octane number requirement.
„h Manifold vacuum controlled spark advance, and reduced manifold vacuum results in less spark advance.
Old Feb 20, 2003 | 10:09 AM
Ruff Ryder's Avatar
Ruff Ryder
Default Re: [Octane] Tuning parameter affects (Tonys96)
This all sounds like interesting information, however……
Shouldn’t we post this type of information in the technical sections?????
No flames intended, but this is the Events section and all of these technical and personalized posts are making it harder for us to read about Corvette Events in the Great Lakes section. Again, no flames intended. :) :)
Old Feb 20, 2003 | 10:12 AM
Tonys96's Avatar
Tonys96
Default Re: [Octane] Tuning parameter affects (Ruff Ryder)
Sure, we've just been having a local tuning discussion.
Old Feb 20, 2003 | 02:04 PM
MinnesotaWhite's Avatar
MinnesotaWhite
Yup, all started with Norths headers and the HP gains through a re-program..
Old Feb 20, 2003 | 08:32 PM
Stingray1967's Avatar
Stingray1967
WHOAH! Now THAT'S a big post. Copy, paste, right? TELL me you didn't free-hand type that big bastitch. :confused:
Old Feb 20, 2003 | 10:07 PM
Bob86ZZ4's Avatar
Bob86ZZ4
Default Re: [Octane] Tuning parameter affects (Stingray1967)
Hay Tony, that's exactly what I think about coming around turn 9 at Brainerd! How did you know? Sorry Ruff, local events again.
Old Feb 21, 2003 | 06:28 AM
Tonys96's Avatar
Tonys96
Multiple copy, paste, edit
Old Feb 21, 2003 | 06:30 AM
Tonys96's Avatar
Tonys96
Default Re: [Octane] Tuning parameter affects (Bob86ZZ4)
Here I go underneath, Bob you're the man, I have to concentrate on Apex's and stuff like that.
To [Octane] Tuning parameter affects
