Ticking fuel injectors
Old Feb 20, 2003 | 02:56 PM
Kizmo's Avatar
Kizmo
Default Ticking fuel injectors
I am getting a lot of loud ticking from my fuel injectors in my 95 Lt1. Is this normal? Should they be replaced, rebuilt or maybe cleaned. If cleaning is required is there an easy way to do this.
Thanks!
Old Feb 20, 2003 | 03:09 PM
Goody's Avatar
Goody
Default Re: Ticking fuel injectors (Kizmo)
Thanks!
Yes it is normal. Yes they can be cleaned. Contact Cruzin Performance for that chore. Cheap too.
Old Feb 20, 2003 | 04:22 PM
YellowC4's Avatar
YellowC4
Default Re: Ticking fuel injectors (Goody)
I have the same problem but don't know if it's fuel injectors or lifter how do I find out
Old Feb 20, 2003 | 04:52 PM
ZylaRace's Avatar
ZylaRace
Default Re: Ticking fuel injectors (YellowC4)
Noisey injectors have nothing to do with them working OK or not.
i.e. Cleaning noisey injectors will not make them quiet.
Some make noise, some make less noise.
Find the noise,... take a long: pipe, rod, socket extension. Put one end on the injector. Put you ear on the other end. You will find the offender in no time.
[Modified by ZylaRace, 4:55 PM 2/20/2003]
Old Feb 20, 2003 | 04:57 PM
87SAM's Avatar
87SAM
I have a mechanics stethoscope, a long screwdriver with your ear held to it would work. Touch each injector with it and you can hear them clicking and decide if that's the noise your hearing.
Old Feb 20, 2003 | 06:42 PM
vader86's Avatar
vader86
Default Re: Ticking fuel injectors (87SAM)
Its your injectors, nothing to worry about, mine tick like crazy.
To Ticking fuel injectors
