L98 Sensor Reading and Tuning
Old Feb 5, 2026 | 05:13 AM
Birb's Avatar
Birb
Default L98 Sensor Reading and Tuning
2 part question for my 1990 L98
1) What is the easiest way to read codes/sensor data, I was going to get any obd1 to usb cable I could find but I’m reading I might need a ALDL cable adapter, if anyone could shed some light or link a brand/product that would work the best.
2) I would like to modify the L98, to produce more horsepower (idk exactly how much I want to achieve but I’m trying to not carb it or just replace it), but I am trying to figure out when to tune it, and I am honestly just confused on what the upper limits of the stock ECM is and when that switch over should happen, so I’m not replacing the chip every time I make a mod. If anyone has any recommendations for this issue that would be amazing, I am a little lost in the first place to start.
Old Feb 5, 2026 | 06:28 AM
Incorvettei's Avatar
Incorvettei
Planning is the key, decide in the modifications you want to do, get them done and then have the chip reprogrammed
Old Feb 5, 2026 | 08:54 AM
ULTM8Z's Avatar
ULTM8Z
I have the Camaro version of your 7727 ECM (the 7730). There's no upper limit on the ECM's ability to be tuned to a new combination. I have 383 putting probably close to 450 hp and the ECM has no problem handling it (tuned it myself actually). Driving it around normally, you'd swear it was bone stock. But stand on the throttle and pretty much goes out of control... lol.... and It could handle 500 hp just fine.
The only issue with these ECM's is that they can be sensitive to modifications. But it depends on how much modification.
Larger runners and base? Change the mufflers? Add headers? Bigger throttle body? Port the plenum? Probably leave the ECM alone. You could retune to potentially optimize a bit, but it'll run just fine without that.
Change the cam/heads? Change the injectors? Definitely need to re tune.
Things that significantly alter the fuel/airflow characteristics will need a re-tune.
The newer ECMs self learning and adapability that make them a little more user friendly. But in the hands of someone who knows there way around these older ECMs, there's really no limit on them.
But I agree with Incorvettei.... you need to figure what your goals are first. Do what you want to the engine... the ECM can be made to work with it.
Old Feb 5, 2026 | 09:02 AM
ULTM8Z's Avatar
ULTM8Z
You might PM Tunedperformancedotorg.
My suspicion is whatever combination you come up with, he's seen it before and probably has the right tune for it.
Old Feb 5, 2026 | 09:28 AM
Tunedperformancedotorg's Avatar
Supporting Vendor
Tunerpro rt shows error code malfunction list when they throw in $8D.
if your not planning to pull the chip every time you can use a ostrich 2 emulator. Or it’s not bad to modify the memcal and use a header under it. I usually solder in a flash eeprom into the memcal and a header adapter can go under it to go in a burner.
__________________
Old Feb 5, 2026 | 09:30 AM
Supporting Vendor
https://tunedperformance.org/store/p...gudx0lfod7bcqy
Old Feb 5, 2026 | 02:13 PM
XLR8-R's Avatar
XLR8-R
Does the above allow monitoring spark knock and total timing/advance?
Old Feb 5, 2026 | 02:40 PM
ULTM8Z's Avatar
ULTM8Z
Yep.
To L98 Sensor Reading and Tuning
