VATS not working?
Old Feb 20, 2003 | 06:53 PM
beachcat's Avatar
beachcat
Default VATS not working?
If it is not working, what are the symptoms?
Will it try to start, ie,,,cranks, but does not start? If so, what is being supressed, gas or spark?
Or will it not even crank?
Old Feb 20, 2003 | 07:21 PM
don hall's Avatar
don hall
Default Re: VATS not working? (thebeachcat)
If the VATS works on the same principle as Pass-Key (later C4s), without a proper module in the ignition key, the starter relay and fuel pump are not activated.
Old Feb 20, 2003 | 10:46 PM
jfb's Avatar
jfb
VATS detects if the proper value pellet is on the ignition key and if it is not, then the start enable relay will not close and the starter will not crank. Also, the injectors will not be pulsed by the ECM.
Old Feb 21, 2003 | 02:22 AM
drive it's Avatar
drive it
:iagree:
And you should have a code stored for vats fail. Unless only the ground on side to the starter relay enable failed....
Old Feb 21, 2003 | 09:05 AM
beachcat's Avatar
beachcat
Thanks, I always wondered how that worked. In that case, I have never had that problem, but the problem I have now is it won't start, it does crank. I come home for lunch, an hour later it won't start. :rolleyes:
No spark and no gas, but the starter does engage.
To VATS not working?
