Brake problems on 94
Old Feb 17, 2026 | 11:24 AM
kenmohr's Avatar
kenmohr
Originally Posted by Geezer94
What was the problem with the calipers? Hadn’t even considered that.
Not sure . had it in shop for other work and they picked up on it. Called and said the calipers were bad. Told them to change them and almost put myself through the windshield on the way home. The were not grabbing
Old Feb 17, 2026 | 12:20 PM
standswithabeer's Avatar
standswithabeer
caliper(s) frozen on the slide/pins, or frozen piston. am guessing.
Old Feb 17, 2026 | 08:51 PM
MatthewMiller's Avatar
MatthewMiller
Even if both front calipers were bad, the rears should still lock up. I still think both people here most likely have a bad booster or vacuum supply to the booster.
Old Feb 18, 2026 | 08:16 AM
Dougk56's Avatar
Dougk56
Default 1994 brakes
I've replaced my booster, and the check valve, but don't know how to judge my vacuum. Also, I've not been able to locate the fuse for my ABS system, to pull and see if there's any difference, but I have no codes or anything pointing to an ABS problem. Still, I haven't been able to rule out a faulty ABS system. Can someone tell me where the ABS fuse is? I looked online with no luck. Plus,does anyone know how to test vacuum efficacy? The only other thing I know to do that I haven't done is to replace brake lines.I see nothing wrong with my lines. Calipers have just been lubed, when I replaced rotors and pads. Master cylinder is new also. Maybe this vacuum is my trouble. How to tell?
Old Mar 23, 2026 | 01:32 PM
Geezer94's Avatar
Geezer94
7th Gear
The problem is solved!!!! After replacing the brake booster with aftermarket Chinese POS, with no change to the braking I have purchased a rebuilt original booster, installed it and the breakes worked great. After chasing this problem for months my recommendation is stay as far away from the aftermarket boosters as you can and have yours rebuilt.
