I have a 1987 with the Doug Nash 4+3, and the clutch pedal developed a "sticky spot?" But it feels like it's hanging up about halfway down. It still operates, and i can still shift without grinding. But past halfway down, the clutch pedal feels HORRIBLE. This is my 1st c4 and my 1st stick shift car altogether. Any advice or pointers?
TIA!
I would guess your clutch master cylinder is getting tired. If it was my car, I would replace both the master and slave cylinders along with the hose that connects them (unless they have already been replaced). The parts are not that expensive, it's relatively easy work, and it could save you from being stranded down the road.
I second this advice. By now, unless you have service records stating the contrary, these are 40 year old parts and hydraulic systems are a wear item. The slave and master are cheap (LuK brand are perfectly fine). The most expensive part is the hydraulic line and next to no one offers it for sale. I went to eBay for mine. Remember this: When bleeding the slave, it has to be removed from the belhousing and the bleeder at the highest point of the assembly or you are going to get an air pocket and get the stiffest pedal ever.
and i will remind you to either suck out and refill the dino non synthetic atf in the od unit assp if you havnt already. if u drop its pan, the right stiff (and only the right stuff for the gasket without overtightening the bolts. cheers. awesome trans! and i run amsoil syncromesh in the 4spd.
Thank you for your help! i checked the master cylinder reservoir; the fluid does look murky, but it's not low or metallic-looking. Definitely needs a flush, but I heard somewhere it could be the pedal bushing that has come apart. is there any truth to that?
you can check, driver seat rearward, phillips screwdriver remove hush panel, care on the footwell courtesy light connector, minful of aldl port connector which can stay in place, flashlight, lay down look up, actuate clutch by hand to see if the binding is from the post. I doubt it. But possible.
Sounds like a good clutch fluid flush is in order.
So I put my car on a hoist to put an eyeball on everything, and make sure there was nothing glaringly wrong. also looked under the dash, and there is a trail of dirty grease coming out of the clutch master cylinder where the pushrod goes in. Is it fair to guess that's my issue?
I put an eyeball on both clutch cylinders, the master says "Manufactured by Repco for Chevrolet" on it not sure if that's original or not, BUT where the pushrod goes in, there is a trail of grease leaking down, is it fair to assume that's my issue?
that sounds like a smoking gun. yeah i would try that first. Sounds like the piston seals have failed inside the bore of the master.
There are rebuild kits, but ive found that usually on these old cars the bore ID itself has corrosion and tears/wears the seals on the piston. A guy coukd diy hone it, or, like i did after giving up on that, buy a cheap clutch master on rockauto.
If you are familiar with different methods of bleeding, be prepared to bleed your system after you open it all up.
At minimum, get all the old contaminated fluid out, prior to installing the master up top.
At best, replace all 3 components, it will start you off with clean internals.
Parts are on the way, and in the mean time i had one of my buddies sit in the car to feel the "stiff spot," and he said the whole throw was oddly stiff, so maybe this has been going on for a while, and it just now got bad. I have a master and slave cylinder on the way.
the job is done, and golly gee I NEVER want to do that again. But it feels much better now thank you for your help!
