95 Coolant Leak, steam pipe fitting?
Old Feb 20, 2026 | 10:28 PM
asthorman's Avatar
asthorman
Default 95 Coolant Leak, steam pipe fitting?
I have coolant dripping off my starter and cant find the source. Based on the location, I assumed the passenger knock sensor but its dry, as is the freeze plug. I pulled the starter and trans inspection cover and the coolant is coming from somewhere above that area.
Nothing obvious up top, all hoses and clamps are less than a year old? I threw a pressure tester on the expansion tank, but that was inconclusive.
How common is a leaking steam pipe bolt/rubber washer?
The car has about 100k. Ty!
Old Feb 21, 2026 | 09:28 PM
Natty C's Avatar
Natty C
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
I don't have a '95, but since nobody has chimed in, it could be orginating from a few places other than hoses or pipes.
There's a core plug (freeze plug) between the trans and engine.
That would suck.
Could be a head gasket.
Mainly sucks, but not the end of the world.
Could be an intake gasket leak. Easy repair.
What's your oil look like?
Old Feb 22, 2026 | 08:47 AM
asthorman's Avatar
asthorman
That would suck.
TY for the reply. The oil is normal. I pulled the flywheel inspection cover and didn't see any coolant evidence from between the engine and trans, thankfully.
Could be an external headgasket leak. There's not a lot of room to see what's going on by the firewall! The search continues 😀
To 95 Coolant Leak, steam pipe fitting?
