If you are ordering a housing and axles, the vendor will ask you what pattern you would like. If you are going to junk yard source the parts, you will need to have the axles drilled for your preferred pattern which might wind up costing more than the ordered performance axles. 4.75" = 120.65mm
Best path is custom built to your specs, very popular and common drag race and high HP restomod standard with the 9” and you can probably go slightly narrower than the current late C4 width hub to hub and retain the GS 17X11 and allow a 315 tire to tuck in nicely without fender flares.
