Super Ram true up
Old Mar 4, 2026 | 04:33 PM
Gale Banks 80''s Avatar
Gale Banks 80'
Default Super Ram true up
Last year I was battling vacuum leaks. Since I was rebuilding the Engine and had the manifold off I thought I would see how straight it was. It took close to 1/16 inch to make it flat no wonder I was having annoying sucking sounds .
Old Mar 4, 2026 | 04:50 PM
mike1111's Avatar
mike1111
cool intake.
Old Mar 4, 2026 | 06:09 PM
ULTM8Z's Avatar
ULTM8Z
Sheesh, that's a lot. I've heard the Super Rams were notorious for that kind of thing.
It was one of the things that steered me toward the Miniram.
Old Mar 4, 2026 | 07:06 PM
C4industries's Avatar
C4industries
I had to do the same thing to one of my Super Rams a couple years ago. Needed to true up the surfaces on the runners and the plenum box. I got everything nice and straight but it took time.
Old Mar 6, 2026 | 06:31 PM
Gale Banks 80'
[img alt="I see we use the same Heads and Rockers. Using the short Poly Locks I needed to clearance the Rockers a bit to clear the Hex in the Lock. Didn't take much I didn't do it the first season they clearance them selves. But now that I knew about it I figured I better do something.
"]https://cimg5.ibsrv.net/gimg/www.corvetteforum.com-vbulletin/2000x1504/17728395976001119395058895514271_45d3877 4666d5fc1f7fa0561de7003fa8f0fea85.jpg[/img]
Old Mar 6, 2026 | 07:53 PM
C4industries
Good to know. I'll keep an eye on it. I noticed that the hex on my polylocks is close to the rocker but it does clear. I'm running a Summit Stage 4 cam with about 0.590 lift using 1.6 rockers.
Old Mar 6, 2026 | 08:43 PM
Gale Banks 80'
You can use shorter Set Screws for a little more clearance depending on how you adjustment comes out. The C4 Magnesium Covers are somewhat thick and can have a little material removed, that is except for the 7-8 Cylinders it looks thin back there.
To Super Ram true up
