87 cooling fan issues what else is new
Otherwise the single wire connection plug on passenger side head, remove that and ground it to turn the cooling fan on.
The early c4 had two temp senders, one for dash gauge the other the ecm. The ecm has its own temp sender to activate the cooling fan, from ecm cooling fan set point or the temp sensor on passenger side engine head between near spark plugs 6 and 8. The ecm also activates the fan when receiving the a/c cooling fan request from that small round pressure switch, the diagnostic port under dash can be used to check fan relay. Connect a paperclip between A and B (the top right terminals) that will activate the cooling fans when turning ignition switch on but not starting car, while in diagnostic mode to check engine codes.
Corvette central sells a lower temp switch for the passenger side cylinder head, for those that want to turn the cooling fans on at a lower temperature compared to factory 238 cooling fan set point. However most people use a simple dial adjustable thermostat temp controller with capillary copper sensor bulb you fit in the top radiator / hose, that can be set to whatever temp you like. Just connect to the adjustable thermostat switch wiring to the temp switch on passenger side head and other side of adjustable thermostat switch to ground.
https://tech.corvettecentral.com/201...modifications/
https://www.ebay.com/itm/332822885693
https://www.corvetteforum.com/forums...eaningful.html
My '96 LT4 runs highway at 183' and lower with ambients below 90', depending on ambient. 195' in town, no higher. Haven't driven it yet in temps >90' on highway or in town, so i don't kow those temps... Yet.. The car is all factory original. Clean radiator/AC condensor, coolant flush, and PCM4LESS flash.
