1984 Corvette Cassette Player
Old Apr 1, 2026 | 10:02 AM
kenziemose's Avatar
kenziemose
1st Gear
Default 1984 Corvette Cassette Player
I have a 1984 C4 corvette, just finished painting and assembly. Most everything from the factory still works. The Radio mostly works, however the antenna doesn't lift, and the cassette player doesn't spin. Is there a good repair kit that can rebuild the cassette player? Or do I need to replace the whole unit? Any thoughts are appreciated!
Old Apr 1, 2026 | 10:26 AM
walleyfisher's Avatar
walleyfisher
For the antenna, check the relay located under the cover at the rear glass hatch latch. it the one that has a screw holding it to the latch brace, the contacts on the relay become dirty and need to be cleaned, there is no replacement available as far as I know without cutting and splicing wires
