Tire vs. Rim Size....Will This Work?
Old Feb 22, 2003 | 09:41 AM
rubyred93's Avatar
rubyred93
Default Tire vs. Rim Size....Will This Work?
Well, I've decided to purchase 4 new tires through TireRack.com but have a small problem. Ideally, I'd like to put 285's on all four corners instead of the stock 255's up front.
Here's the issue: Tire Rack states that the 285's need a minimum of a 9" rim. That is fine for the rear of the car, but I am off by 1/2 inch on the front (8.5" rims up front). Will putiing the 285's on the 8.5" rim be a bad idea? Do you think that the side wall will bow out too much?
Anyone have any experience/knowledge with this type of thing? Will the 1/2 inch matter that much? What do you guys think? :confused:
Old Feb 22, 2003 | 10:44 AM
vader86's Avatar
vader86
Default Re: Tire vs. Rim Size....Will This Work? (rubyred93)
I dont think that will look right at all. What about 275s all around?
Old Feb 22, 2003 | 10:50 AM
VetteNoob's Avatar
VetteNoob
you could also buy 2 9.8" rims for the front and then you can go 285 all around. i wouldnt go 285 on 8.5" wheels. imagine shoving some 335s on 9.5" wheels or something. :crazy:
Old Feb 22, 2003 | 04:56 PM
rubyred93's Avatar
rubyred93
Default Re: Tire vs. Rim Size....Will This Work? (VetteNoob)
Yeah, I think you guys are right, it's not a good idea. I'd consider buying two 9.5" rims for the front, but I just bought the two 8.5" sawblades that are on there now, and they are in perfect condition.
Oh well. Thanks for the responses, I think I'm going to stick with the stock tire sizes. At least it'll be all new rubber just in time for Spring. :) Thanks again. :D :seeya
Old Feb 22, 2003 | 05:10 PM
Snackdragons's Avatar
Snackdragons
I have 285s on the rear and 275's up front. i hear 285's fit upfront, but i'd need another set of rims, the stock rims fit 275's no problem.
Old Feb 22, 2003 | 07:47 PM
rubyred93's Avatar
rubyred93
Default Re: Tire vs. Rim Size....Will This Work? (Snackdragons)
I have to make a correction here (I've been looking at too many numbers, and didn't have things exact) as I went back and checked TireRack.com once more for appropraite rim sizes.
The 285's require a minimum of 9.5 and the 275's would need a 9" rim minimum. That does not seem to help my cause, but it is a clarification. I'm still off by .5" on the front. I thought about the 275's up front, but TireRack says no. ??
I like the wider rubber, even if it's only 10mm, but asking it to hug a narrow rim may not be a good idea. :steering:
Old Feb 22, 2003 | 08:29 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
:cheers:
I went to Y2K wheels which I believe are 17 X 8.5 on the front and used my 275's (from my old '88 wheels) with no problem. I have run them at reasonably fast autocross track for many consecutive laps and had no problems
FWIW :D
:steering: [ I love that Lil Guy! ]
Old Feb 23, 2003 | 01:59 AM
Snackdragons
275's fit fine on the 8.5" rims. I have many road race and autoX's under my belt. However the 9.5" rims would put less stress on the tires sidewall. I notice no sidewall bulging at all with the 8.5" rims. so i doubt the different is significant.
Old Feb 24, 2003 | 01:49 PM
_freakmonkeydogboy_'s Avatar
_freakmonkeydogboy_
275's fit fine on the 8.5" rims. However the 9.5" rims would put less stress on the tires sidewall.
:withstupid:
Old Feb 25, 2003 | 11:17 AM
flubuyu2's Avatar
flubuyu2
I have a '93 as well and it came with 9.5's in the front...yours didn't? or were the ones you bought smaller? anyway I've pushed the limits of the rim size before seeing as I don't race (offically at least) and am interested in the looks.....yes yes I'm one of those guys with 315's on 9.5" rims alittle squishey around the curves but in a straight line traction like no other!
Old Feb 25, 2003 | 01:01 PM
Lichen's Avatar
Lichen
Default Re: Tire vs. Rim Size....Will This Work? (flubuyu2)
93's came with 8.5's in the front
Old Feb 25, 2003 | 02:45 PM
_freakmonkeydogboy_
Default Re: Tire vs. Rim Size....Will This Work? (Lichen)
unless it was z07/z51, they had 9.5" all around :D
Old Feb 25, 2003 | 03:25 PM
*89x2*'s Avatar
*89x2*
From: ...tearing up the highways, one state at a time™®©
I have 285's on my 93 convertible at all 4 corners (only EMT run flat tire I see is avail- unless I missed something) 9.5" wheels all 4 corners :thumbs:
Old Feb 25, 2003 | 03:34 PM
TravisD's Avatar
TravisD
Keep in mind that the smaller rim will effectively pull in the sidewalls, reducing your contact patch - the wider rubber may not do you any good from a performance perspective. It's just wasted money assuming that the 285's are more expensive than the 255's
Old Feb 25, 2003 | 03:59 PM
86_RedRider's Avatar
86_RedRider
Cruise-In V Veteran
St. Jude Contributor '03 & '05
Default Re: Tire vs. Rim Size....Will This Work? (TravisD)
what's the benefit of having a wider tire in the front anyways? visually there is none because you really don't see the front tire's width and as far a performance it's not like it's a front wheel drive car. i guess your cornering would be a little better, but for like a 1/4 mile track, does it really matter?
Old Feb 25, 2003 | 05:00 PM
Snackdragons
Default Re: Tire vs. Rim Size....Will This Work? (86_RedRider)
the whole point of a vette is the handling, so wider is better up front. however, if you just wanna drag race get a pony/muscle car like a mustang/fbody.
Old Feb 25, 2003 | 08:18 PM
TowerMan's Avatar
TowerMan
St. Jude Donor '08
Yo I have a 91 with 93 faced polished wheels. 8.5 in front - 9.5 in back. I have 275 firehawks on all - no problems. I know at least one other that put 275s on 93 wheels. The firestone specs give the range with for 8.5 to 9.5 for the 275s. :cheers:
To Tire vs. Rim Size....Will This Work?
Old Feb 25, 2003 | 09:29 PM
flubuyu2's Avatar
flubuyu2
I didn't know it came w/ 8.5's I guess the orig. owner swapped them.....I did however take a look and both my rear wheels say right rear on the inside of the rim ....does that matter I have no left rear ??
I do only have 275's in the front will a 285 rub w/(again) a 9.5" rim?
Learning about this subject is soooo much fun! :seeya
Old Feb 25, 2003 | 10:03 PM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Your wheels should say right side and left side.. They also have the rim size stamped in them..
Old Feb 26, 2003 | 07:21 AM
rubyred93's Avatar
rubyred93
Default Re: Tire vs. Rim Size....Will This Work? (TowerMan)
TowerMan -
How do the sidewalls look on the 8.5" rims? Does the sidewall bow out more than the 9.5" rims?
When I called TireRack yesterday, I was told that a 275 will fit an 8.5" rim. When I presssed the sales rep. for any performance drawbacks to putting the 275 on the 8.5" rim, he did say that the sidewall would bow out more. That's what I had figured.
What do you think about how it looks? Is it possible for you to post any photos of the front wheels/tires? Thanks. :)
