Thermostats
Old Feb 22, 2003 | 12:25 PM
Hamert's Avatar
Hamert
Default Thermostats
Does it really make a difference going to a 160* thermostat on an LT4? I wouldn't think it would do any good unless you reprogrammed your fans also.
Old Feb 22, 2003 | 01:15 PM
STL94LT1's Avatar
STL94LT1
Default Re: Thermostats (Hamert)
160* stat does very little without fan reprogramming, especially in hot weather.
Old Feb 22, 2003 | 04:03 PM
Lone Ranger's Avatar
Lone Ranger
Fan programming is the key, regardless of 180 or 160 tstat.
Old Feb 22, 2003 | 04:32 PM
Alex D's Avatar
Alex D
Default Re: Thermostats (Lone Ranger)
Not quite true......I have a 160F thermostat and did not reporgram my fans just simply because I don't have a HPP3+......it still works fine.....in the summer in town all I need to do is turn the heater control to a setting that engages the A/C an the fans come on automatically below 40 mph and keep the car at 175-180F coolant temp forever in city traffic. On the highway or interstate, the engine and tranny now run significant cooler than before: depending on ambient temp the engine runs at 177 to 190F and the tranny at 160-200F.....before the engine always ran at 200 to 210 F and the tranny too.....so it has a
beneficial effect to run the 160F thermostat without reprogramming the fans...
Old Feb 22, 2003 | 04:44 PM
vader86's Avatar
vader86
Default Re: Thermostats (Alex D)
I believe its more important to have your fans reprogrammed with the LT1. You already have a 180 tstat from the factory, i think that should be perfect for CT weather.
To Thermostats
