This fall/ winter I am planning on building the motor on my 87. It would be a 383 stroker, thinking miniram intake, AFR195 heads, and a cam (Duration 308/316, Lift .555/.555). The reason i am doing this cam and head combo is that it comes as a kit meant for 383s. My newest question is, how am I gonna make this thing run? can the factroty PROM computer handle this? can i find a EPROM wizard and make it work? what do i do if it wont? any help here is greatly preciated.
The trick these days is finding people who will tune it, but yes it can be tuned with factory ECM. It needs to be done on a dyno and then you need to drive the guy around, all the real work in tuning is in driveability.
This is fantastic news. Do you happen to know anyone in mid-Michigan who does it? i read up on some aftermarket ECUs, and a lot of them don't support the digi dash, and for some reason, having a working dash is high up on my list of priorities (probably too high)
With an 87 using an aftermarket ECM would only lose the the mpg/range display. The gauges will still work. Even the speedo works directly off the speed sensor in the transmission.
Yeah, and with cams that big, part throttle AFR's can be very tricky to dial in with these factory ECM's that placed a lot more emphasis on emissions... you can end up with part throttle AFR's that are much leaner than what you'd want for a performance oriented engine rather than an emissions oriented one.
With my own experience on the later 7730 ECMs (which I suspect behave similarly) with my much smaller cammed 383 and another guy I'm helping with a 383 cammed similar to what you're planning... I'm barely able to run closed loop on mine (have tweaked a lot parameters that result in behavior that some might argue isn't even true closed loop anymore)... and on the guy I'm helping I'm pretty much advocating him to just run open loop and tune AFR's via his Wide Band O2.
