No more TCC after engine restart
After 10 months of work (interior, engine...), I was able to restart my 86. Everything seems to be working.
However, I haven’t had a TCC lock since the restart... Before, everything worked.
I made a modification to the wiring of the TCC, but I have a mode that allows you to switch to the original mode.
Original wiring diagram :
Modified wiring diagram : this allows either to drive in original mode, or with the TCC disconnected, or with the TTC activated with an preset engine vacuum (as an additional condition).
I checked the voltage, all is allright.
I do have a 12v output from the TCC pedal switch (purple wire), when needed. I added a LED (with resistance) betwenn this wire and F pin from ALDL.
BUT :
No TCC, no LED.
I checked the LED, I put the LED to the ground, it lights up. So I do have 12V again, with the purple wire of the brake pedal.
I think I've a problem with F pin.
Yet, the ECM seems to change state beyond 67km/h (42mph).
From this speed onwards:
- the voltage between F and ground changes from 12v to 0V
- The resistance between F and ground changes to 180 ohms. Is this normal?
I would have been inclined to think that F = mass (that is, less than 1 ohm) above this speed?
I worked on the engine intake. Did I forget to connect something?
I unplugged and replugged the ECM during my months of work (battery disconnected).
While driving, I connected F to A (on the ALDL), nothing happened either, I thought the TCC would have been forced, but no.
Does anyone have an idea ?
Does F become a continuity with ground when the speed exceeds 67km/h ?
Thank you
I presume it was the problem.
I took it apart, cleaned it because it was oxidized, and slightly tightened the contacts for better support, and checked that everything was flowing perfectly. It has regained its function !
Just more than to be tested at the next trip.
On the other hand, with this connector disconnected and ignition ON, I do have some 12V as input (pink striped black wire no. 39) : okay.
But I also have 12V on the output wire (purple wire no. 420), and that I don’t understand ?
It is indeed the TCC switch, coupled with the cruise control depression. The wires are indeed pink/black, and purple.
I tested the Corvette, the system works perfectly now.
