Okay, LT1 with 56k miles. I recently had an opti problem so I have new plugs, wires, opti, water pump, cleaned throttle body and IAC valve, and replaced intake manifold gasket and a bunch of of vacuum lines. Lately, I have been chasing this idle surge that happens at idle, local corvette guy said it’s most likely clogged fuel injectors but the car runs great other than idle so not sure. something happened this morning. I’ve been getting an H41 code for a few months now, as long as that idle surge has been there. This morning, I was doing a decently hard pull and then the car shut off. Checked the codes and holy ****. H41, H54, H16, H48, H36, and H72. Is my ECM fried? What should I check. Car started immediately after and drove fine.
If I remember correctly, the 16 code could point to the Opti.
the codes I got point to like 6 different things, I’m pretty sure the ecm just had a spasm and outputted those codes, I havent had any opti problems or codes besides that H41 code since I changed it.
got home, drove relatively fine, almost stalled when I started it hot, but I heard this sound, what is this?
