Can anyone please read my tunerpro RT capture file and tell me if I should be concerned about my ecu adding fuel?
It's a stock L31 engine with the vortec heads / tpi adapter. all is stock and emissions are intact.
Its a $6E log (ARAP). The 150-160 Cell 0 BLM is concerning. I don't have a good free csv log viewer available at the moment, so I didn't look closely into the entire file and don't want to purchase a log viewer just for this purpose.
Datazap (the free version) is now limited to 100 logs (and I'm way over the limit, so I cant upload any more logs). Don't want to pay for MegaLogViewer HD either.
Your closed throttle TPS voltage is .47 volts. I don't think that's necessarily your problem, but generally you want the closed throttle TPS voltage to be .54V.
yeah but the huge disparity between idle cell and everywhere else is interesting.... his BLMs are pretty normal everywhere else.... even at similar pulse widths to idle.
