Tire Pressure
Old Feb 23, 2003 | 11:34 AM
aroulette's Avatar
aroulette
Default Tire Pressure
For normal cruising, what do you run at? I noticed I have ran about 30-32psi, but the tires call for 44 max psi. I added to 38 and ride is much rougher. Any suggestions?
Old Feb 23, 2003 | 11:41 AM
vader86's Avatar
vader86
Default Re: Tire Pressure (aroulette)
44 is the MAXIMUM pressure you can run, not the recommended. Your ride is indicative.
between 32-35psi is where you should run them
Old Feb 23, 2003 | 11:43 AM
SPEED750's Avatar
SPEED750
Default Re: Tire Pressure (vader86)
Recomended tire pressure is located on the sticker in your door jam. :chevy
To Tire Pressure
