Turbo Ideas (long)
Obviously where theres a will, theres a way.... MN_VETTE is doing and under motor TT system... He only has one side done so far.... Look in the post frustrated part 2 for his pictures.....
Your probably going to have to use internal wastegates to save space too....
I suggest you go and get a book called Maximum Boost by Corky Bell..... It goes through how to pick out turbos, how do design your own custom system and everyting else there is to know about them....
Turbo is sooo cool...... A lot of work though
JMHO
The other thing to remember is that the displacement will only help with low end torque and possibly reliability issues with a turbo setup. HP is calculated by airflow through the engine, hence why 3.0L supras can still get 1000HP. The turbo will have more to do with your HP then the displacement once the turbo is spooled.
[Modified by mn_vette, 12:11 AM 2/25/2003]
Anyway is their even enough room to mount Turbos underneath? You know not no 150HP rated tiny Turbos, bigger ones than that. Also MN vette, how much power do you plan on making with your setup? :thumbs:
Getting sideways at 100 cant be much fun.... lol.... Gotta love Callaway
Chris
Also how can I tell if I have a Dana 36 or 44? I think the previous owner might have changes it because it has 3.54 gears instead of the stock ones. So how could I tell if its a 36 or 44, I do know that in 84 they did not offer them, but I dont know if the previoud owner had changed them. :confused:
the good news.... of all the C4 corvettes, your 1984 C4 along with the 1985 C4 came with a different set of spindles then their latter counterparts. the much desired 84/85 spindle and hub assemblies are much stronger then the 86-96 sets and are not nearly as prone to fail. however, the next step above that is a chromoly set or perhaps to have your set dressed for stress risers and maybe nitrided for more integral strength at the metals molecular level. as for half shafts, they do make some aftermarket replacements in a stronger aluminum series and a carbon fiber series. last i remember, Lingenfelter sold the carbon fiber sets for around $300 a set.
for everyone else, an informative about the 86-96 spindle hub assemblies.... the spindles seem prone to break by shearing at the base of the small splined shaft step where the the thrust washer on the spindle meets the bearing face of the hub/wheelbearing assembly one way to help prevent premature break under duress is to keep the wheel bearings in their specified runout specs... do not use bearings that are beyond allowable wobble. this puts the spindles in a bind with good traction and will certainly increase the chance of breakage. its a common problem with the driveline. wheelhop will also kill a spindle quickly as well as wipe out your rear wheel bearings. spindles generally can be had for about 75 bucks used from salvage yards and are around 150 clams new per piece. when a spindle breaks it can sometimes cause a series of broken pieces including destroying the hub assembly, and almost always the ABS sensor, and usually puts a tremendous strain on the posi unit. so theres my piece on those topics i know its a little off topic for this thread but in pertaining to handling the new found power of a turbo it kinda relates :D good luck and lets keep these turbo threads alive.. its great subject matter!
Chris
Chris :D
