1984 Crossfire keeps stalling at low speed
Old Jun 3, 2026 | 06:55 PM
Amsi10's Avatar
Amsi10
2nd Gear
Default 1984 Crossfire keeps stalling at low speed
Been chasing this issue for a while.
The car runs great otherwise, starts right up every time and pulls strong. No codes except Code 12.
I replaced both IACs recently and that got rid of the strong fuel smell, so it definitely helped.
My problem now is that every once in a while, when I’m just creeping through a parking lot or slowing way down, the RPM drops and the car stalls.
TPS checks out fine at 0.49V closed and 4.61V WOT.
Anyone run into something similar?
thanks 🙏🏼
Old Jun 3, 2026 | 07:26 PM
ex-x-fire's Avatar
ex-x-fire
Unplug the egr valve and go drive it. If the egr solenoid is bypassing a little it could cause it to stall.
Old Jun 3, 2026 | 08:09 PM
Amsi10's Avatar
Amsi10
2nd Gear
Default Egr
Do you mean unplug the vacuum line from the EGR valve, or unplug the electrical connector from the EGR solenoid?
thanks again
Old Jun 3, 2026 | 08:28 PM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Love my 82 found this on the L83 many years ago..Also had a few 84's
https://www.corvetteforum.com/forums...solutions.html
Old Jun 4, 2026 | 01:43 AM
typical boomer's Avatar
typical boomer
Had similar issues with my '84. Turned out the EGR valve itself was bad. I was having throttle tip in hesitation and stalling when lifting off the gas pedal. New EGR valve and IAC's along with chasing down all vacuum leaks fixed everything. Been running great ever since. Here is a link to my original post.
https://www.corvetteforum.com/forums...-stalling.html
Old Jun 4, 2026 | 07:00 AM
ex-x-fire's Avatar
ex-x-fire
I'd unplug the egr valve vacuum connection, you could go as far as hooking up a vacuum gauge to it to verify if it is getting vacuum at idle (which it shouldn't).
To 1984 Crossfire keeps stalling at low speed
