Spark plug gap?
Old Feb 23, 2003 | 06:59 PM
R23HTC's Avatar
R23HTC
Default Spark plug gap?
Since I’ve been having continuing problems in the higher rpms, I decided to replace the spark plugs today to see if that would help. I was told the spark plugs that were in there should have been gapped at .050. Since they were NGK TR55’s they would have to have been done. Those plugs normally come gapped around .055. On a side note, the ones I just bought were gapped at .057. Anyway. I had thought maybe the plugs were blowing out in the higher rpms so I closed the gap to .045. Took the car out after warming it up and that seems to have helped some. What I’m wondering is this? What effect does the gap have on the way the motor runs? I know you don’t want it to small or it won’t burn all the fuel. To big and it’ll flame out in the higher rpms range. How can I tell by the way the motor is running if I’ve got it right?
BTW, the ones I took out were gapped like this:
1. .059
2. .059
3. .059
4. .060
5. .059
6. .057
7. .060
8. .059
Old Feb 23, 2003 | 07:56 PM
Lone Ranger's Avatar
Lone Ranger
Default Re: Spark plug gap? (R94 LT 1)
.050 is book spec on LT1's. Be careful regapping plugs, you want the ground strap to be as parallel to the electrode as possible.
I have the TR55ix iridiums installed and like them.
Old Feb 23, 2003 | 08:01 PM
Lone Ranger
Well duh on my part-- just saw your sig. I'm pretty sure that when LPE and MTI do 383's they reduce the plug gap. I'm sorry not to be more specific but I do remember seeing a spec on a 383 where the plugs were gapped 0.035. Maybe you're getting detonation too, and one heat range colder plug NGK TR6 (?) might help?
Old Feb 23, 2003 | 08:54 PM
R23HTC's Avatar
R23HTC
Default Re: Spark plug gap? (Lone Ranger)
I hadn't thought about going cooler. I know a few in our club run cooler, but I thought that was more because they run nitrous. Not sure I want to go down to .035. I maybe a few more with modified motors will chime in.
Old Feb 23, 2003 | 11:02 PM
VMAX451's Avatar
VMAX451
Switching from the stock AC's gapped at factory spec to NGK TR5's (.035) fixed my high rpm misfire. But, I should mention that two of the AC's were missing their pucks, so I don't know if that was the problem. In any case it ran fine with the TR5's for 10k miles. I just got a set of TR55's and will gap them to factory spec to see how that goes, I'm thinking it was bad plugs in the first case, not necessarily the gap.
Also, I called LPE since I was using one of their cams and asked them what they use and they told me .035.
Old Mar 1, 2003 | 04:43 PM
R23HTC's Avatar
R23HTC
Default Re: Spark plug gap? (Vince Ivanc)
Looking for more input. TTT
Old Mar 1, 2003 | 07:46 PM
purpleTPI84's Avatar
purpleTPI84
5th Gear
Spark Plug gap should be determined by the ignition manufacturer..ie if its stock go with what the book says , the plug should be gaped to what the ignition sys is setup to need ....just my .02 :thumbs:
Old Mar 1, 2003 | 09:07 PM
AlHale's Avatar
AlHale
Default Re: Spark plug gap? (purpleTPI84)
I have an LPE 383 and have the paperwork that says to set at .035".
Old Mar 1, 2003 | 09:18 PM
R23HTC's Avatar
R23HTC
Yes, and if it was stock, I would tend to agree with you. Check my sig, there's nothing stock about it. :D
Old Mar 1, 2003 | 09:19 PM
R23HTC's Avatar
R23HTC
Default Re: Spark plug gap? (AlHale)
I have a feeling I'm going to be busting and scraping my knuckles again. :mad
What kind of ignition do you have? ie........wires, plugs, coil?
Old Mar 1, 2003 | 09:21 PM
AlHale's Avatar
AlHale
Accel 300+, Magnacore wires, Champion plugs
Old Mar 1, 2003 | 09:25 PM
R23HTC's Avatar
R23HTC
Thanks.
To Spark plug gap?
