Removing Camber Brace How to?
How hard is it to remove myself, so I can send it back for modifying
to fit a electric water pump. Any tips/techniques for removing camber brace would be appreciated.
you need to remove the 2 forward big nuts that hold the upper control arm in place.
it would be helpful to remove the splash guards, too.
the belt will have to be relieved, but not removed, so the bolt on the drives side can be pulled out.
make sure you don't loose the shims, either. note which side they were on.
