HELP ZF shifter problem
Old Feb 25, 2003 | 12:07 AM
wheeljo2's Avatar
wheeljo2
Default HELP ZF shifter problem
I think maybe it's time to replace the transmission mount in my 94 ZF Tranny. Under part and hard acceleration, the shifter handle bucks up like a bull.
How many mounting points are there? Has anyone changed this mount before? Can you lend some insight into the installation?
Muchos gracias,
Ruedas (Wheels in Spanish)
:cheers:
Old Feb 25, 2003 | 12:51 AM
88-406's Avatar
88-406
St. Jude Donor '05
Default Re: HELP ZF shifter problem (wheeljo2)
I'm in the process of installing a ZF in my 88. And unless I'm missing something with my parts, there are only 3 mounting points. The two motor mounts andd the torque arm which is a hard point.
If you find out otherwise please let me know.
KM
Old Feb 25, 2003 | 02:06 AM
pablocruise's Avatar
pablocruise
Some minor movement is normal. Check your motor mounts or the C-beam tho.
Old Feb 25, 2003 | 02:23 AM
GS Ragtop's Avatar
GS Ragtop
From: Michigan in the summer, Florida the rest of the time
St. Jude Donor '08-'09-'11
Default Re: HELP ZF shifter problem (89 Paul in Cal)
:yesnod: :yesnod: Sounds like the C-Beam bolts have worked loose. Let's everything flex like crazy under hard acceleration.
Brad
Old Feb 25, 2003 | 02:30 AM
wheeljo2's Avatar
wheeljo2
Default Re: HELP ZF shifter problem (GS Ragtop)
Thanks. How many bolts are there and where are they located??
Old Feb 25, 2003 | 02:44 AM
GS Ragtop's Avatar
GS Ragtop
Here's a pretty good picture of the bolts from Bill Beadreau's ZFDoc site:
You might want to drop Bill a note and let him suggest a troubleshooting path to take...
Brad
To HELP ZF shifter problem
