Rack And pinion
Old Feb 25, 2003 | 02:23 AM
jtfrog's Avatar
jtfrog
Default Rack And pinion
Getting ready to install new rack, How2 do you make sure it is centered before hooking it up
Old Feb 25, 2003 | 11:08 AM
don hall's Avatar
don hall
Default Re: Rack And pinion (jtfrog)
I'm not sure if this answers your question, but these instructions are for Rack Bearing Preload: Make adjustment with front wheels raised, and steering wheel centered. Check returnability of the steering wheel to center after adjustment. Loosen adjuster plug lock nut and turn adjuster plug clockwise until it bottoms in gear assembly, then back off 50 to 70 degrees (about one flat). Then lock nut to adjuster plug.
Old Feb 25, 2003 | 11:28 AM
jtfrog's Avatar
jtfrog
not sure, i heard that when people change their rack that the steering wheel is no longer centered and to adjust the tie rod ends to fix this. also they say to center the rac i asume frome lock to lock before instalation :confused: :confused:
Old Feb 25, 2003 | 11:40 AM
don hall's Avatar
don hall
The data provided was the only adjustment noted in the GM manual, and it referred to a drawing of the rack and pinion. I had hopes that the info would be more meaningful to you than it was to me. Maybe some member who has experienced this installation will prolvide some insight. My other manuals don't even mention a centering requirement.
To Rack And pinion
