removing cats
Old Feb 26, 2003 | 05:01 PM
Clemson Vette's Avatar
Clemson Vette
Default removing cats
hey i'm wanting to remove the cats from my 95 vette. are the o2 sensors before or after the cats and will this set off a code and light on my dash warning system? if it does, is there anyway i can bypass it? ie a plug kit or do a little rewiring? i would also like to remove all the smog junk from my car. can i just unbolt it and tie the wiring up out of the way? or will more lights go off? again, is there anyway i can fix this if it does happen? i dont need to worry about emissions in sc! please help me with your expertise guys. :flag
Old Feb 26, 2003 | 05:34 PM
Zix's Avatar
Zix
Default Re: removing cats (Clemson Vette)
You need the front O2 sensors, but if you're removing the cats you can get rid of the rears. However, you will either need to have your computer reprogrammed so it doesn't throw a code or go buy some O2 simulators...I think Summit has them.
Old Feb 27, 2003 | 12:40 AM
Clemson Vette
Default Re: removing cats (Zix)
ok i didnt know there were two sets. i saw those simulators and they look like the way to go. but they dont have any for my car. know where i can get some? and i dont know if i already asked this, but can i remove all that smog crap on my car easily ie unbolt and unhook hoses. and strap the wires up? or will this require more simulators and code fixin?
Old Feb 27, 2003 | 01:34 AM
Darkness's Avatar
Darkness
Thats the way to go :cool:
Old Feb 27, 2003 | 02:12 AM
Zix's Avatar
Zix
Take a look to see if you have a flat 4-pin connector on the O2 sensors, if you do there are lots of places to get them, if not give Trevor a call at Exoric Muscle, he should know where to find some and point you in the right direction. His number is 480 967 4222
Old Mar 6, 2003 | 09:11 PM
Clemson Vette
well i got my ripper shifter today and with it came a new jegs catalogue. it has some of these cat simulators in it, but again, none for my car. so can i get some for any 5.7 liter engine? will that work? havent looked at the actual harness yet, but i will this weekend. can someone please post a link where i can find them for my car. and just so i have this straight, there are 2 sets, one before the cats and one after. leave the ones before as is and plug simulators into the ones after the cats. right? what about when i get headers? do i still drill and tap the front o2 sensors into the exhaust? i think so but wanna make sure.
Old Mar 6, 2003 | 10:53 PM
USAsOnlyWay's Avatar
USAsOnlyWay
Breathless Performance.... they make a pulley so you rip the air pump out completely. Then just get rid of all that stuff and get your chip reprogrammed...
Old Mar 6, 2003 | 11:57 PM
vader86's Avatar
vader86
If you want to work on your car, you need a Helm Manual before you screw something up.
helminc.com
best money youll ever spend
To removing cats
