QUESTION ABOUT ROLLER ROCKERS
Old Feb 27, 2003 | 07:46 PM
SPEED750's Avatar
SPEED750
Default QUESTION ABOUT ROLLER ROCKERS
Need some advice about 1:6 roller rockers.I have a 92 LT1 and I would like to put RR on but it has guide plates.I was told not to use self aligning rockers if you have guide plates.That rules out the Crane LT4 RR,has anybody used cheaper models with good results.(energizer,proform,ect) :rolleyes:
Old Feb 27, 2003 | 08:54 PM
FoolCrzy's Avatar
FoolCrzy
Default Re: QUESTION ABOUT ROLLER ROCKERS (SPEED750)
Crane makes non self-aligning rr's...
Old Feb 27, 2003 | 09:02 PM
VMAX451's Avatar
VMAX451
...I have a 92 LT1 and I would like to put RR on but it has guide plates...
If it's factory stock, those aren't true guide plates, they're just "convenience" pushrod holders. The stock stamped rockers are self aligning. If someone replaced those with true guide plates, then disregard what I just said.
Old Feb 27, 2003 | 09:08 PM
Strick's Avatar
Strick
I have a 92 LT-1 and I installed the Crane self-aligning-narrow body 1.5 ratio aluminum rocker arm set Part # 10751-16 and hardened pushrods Part # 10621-16. The only thing you have to do that , if you want to keep the original valve covers, is grind off the oil drip tangs on the inside of the covers. This makes room for the rocker arms. The engine runs much better. I installed them just for reduced friction in the valve train.
SEE YA
Strick
Old Feb 28, 2003 | 12:02 AM
Fatt Vette's Avatar
Fatt Vette
Default Re: QUESTION ABOUT ROLLER ROCKERS (Vince Ivanc)
When I first read this post it scared the crap out of me! I just finished this particular exercise on my L98, I didn't even think twice about the faux guide plates. I just went out in the garage and looked at the stock stamped rockers that came off the car, sure enough, they are self aligning.
I guess I am OK, stamped self aligning came off, roller self aligning went back on.
Old Feb 28, 2003 | 03:12 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: QUESTION ABOUT ROLLER ROCKERS (Fatt Vette)
I believe you are correct since the OEM guide plates were only used for rough indexing of the pushrods during assembly.
I recommend installing new machined keepers to minimize the chance of a dropped valve.
For those with a late L98, toss the oil shedders atop the springs to lighten the valve train and so raise the valve float limit.
Old Feb 28, 2003 | 03:28 AM
ANUTT's Avatar
ANUTT
HMMM!!! mine did not have guide plates..I am running crane 1.6s self aligning with no problems..... If you up the ratio you will need to change the springs our ...crane part# 10308
Old Feb 28, 2003 | 09:16 AM
VMAX451's Avatar
VMAX451
Default Re: QUESTION ABOUT ROLLER ROCKERS (ANUTT)
Just a warning, I had clearance issues with the Crane 1.6's and the 10308 springs (trunion to retainer), I've heard it's a hit or miss thing. Also, the 10308 springs won't fit the stock locators, so Crane's solution is to supply shims with too big of an inside diameter that will "hula hoop" around the guide. Neither me nor several machine shops could find shims of the proper dimensions, no one makes them, so you have to either use Crane's solution or work something else out.
Old Feb 28, 2003 | 03:46 PM
C4Crazy787's Avatar
C4Crazy787
I was told by Comp Cams tech could'nt use 1.6 RR with my stock cam
(piston to valve clearence). I was all ready to slap those bad boys on,
but now I'am not sure. I knew about the valve cover tabs & springs but I was'nt ready to hear that. :crazy: Well just set back awile and do some more research. :seeya
Old Feb 28, 2003 | 04:18 PM
VMAX451's Avatar
VMAX451
Default Re: QUESTION ABOUT ROLLER ROCKERS (C4Crazy787)
:skep:
Coil bind may be an issue with the stock springs, but piston to valve clearance is not going to be a problem on a stock LT1 with 1.6's.
Old Feb 28, 2003 | 04:28 PM
C4Crazy787's Avatar
C4Crazy787
Yea, :skep: is right . I got a post into Jeff Kopp on his fourm, I will find out what's up, then just buy the GM RRs from him. That Comp. guy messed up
I was ready to order the Pro Mags, oh well. :seeya
To QUESTION ABOUT ROLLER ROCKERS
