Headers & no cats cause lean condition?
Old Feb 28, 2003 | 10:51 AM
dscottr's Avatar
dscottr
Default Headers & no cats cause lean condition?
I just had Lt headers installed and deleted the cats, added heated o2 sensors, now I've got a service engine light. The code is for a lean condition. Is there a cause effect situation here. My air fuel was perfect 12.0 before. I am having it put on the dyno this afternoon and check air fuel again. Looks like I may have to give Ed wright a call.
[Modified by dscottr, 10:52 AM 2/28/2003]
Old Feb 28, 2003 | 12:27 PM
Aaron's 87's Avatar
Aaron's 87
Default Re: Headers & no cats cause lean condition? (dscottr)
IF you're getting a lot more air out, then you COULD be getting a lot more air in and screwing up WOT fuel. I think a more likely explanation would be an exhaust leak.
Old Feb 28, 2003 | 11:48 PM
SHiNoBi LT4's Avatar
SHiNoBi LT4
Default Re: Headers & no cats cause lean condition? (Aaron's 87)
interesting. let us know when you figure it out plz.
Old Feb 28, 2003 | 11:49 PM
scorp508's Avatar
scorp508
It shouldn't affect it THAT much. Did you retorque the headers a few times after a few heat cycles?
Old Mar 1, 2003 | 11:18 AM
dscottr's Avatar
dscottr
Default Re: (scorp508)
After putting it on the dyno and changing the o2 sensors a second time, I am going to give ed wright a call. I am told that the headers and no cats are causing a timing issue with the fuel injection. It is real lean from 2,200 to 3,300 rpm.
Air fuel was 12.0 across entire curve before changes. Now 13.8 at 2,100; 18.0 at 2,500; 17.6 at 3,300, and then back to 14.s and 13.s after that. All of these numbers are under the same fuel pressure, 42 psi. We tried increasing the fuel pressure and then engine ran terrible.
Old Mar 1, 2003 | 11:50 AM
vader86's Avatar
vader86
Default Re: (dscottr)
This would affect a carbed car, it shouldnt affect an FI car much, i suspect an exhaust leak or a bad program.
Old Mar 2, 2003 | 07:08 PM
dscottr's Avatar
dscottr
Default Re: (vader86)
There are no exhaust leaks. It was on the lift 2 days ago. Although I haven't retorqued the headers yet, they were just put on and I've only driven about 150 miles so far.
But the car is running so bad, that I can't believe that headers and no cats could cause this much havoc. You can't drive the car in traffic at all. The engine sounds like it is totally breaking apart from 2 grand to 3,200 rpm and then it takes off like there is no problem. You can drive it around in first and second and keep the rpms over 3 grand, but as soon as you have to stop the car spits and sputters and you have to floor it to get it to go anywhere. Then when it kicks in the car takes off.
Old Mar 2, 2003 | 07:19 PM
scorp508's Avatar
scorp508
I'm really lost for words here. If you TRULY are running 18:1 you should park that baby until you have it figured out. Thats downright dangerous if you go full throttle. You don't want to melt a piston. Its possible that you have a leak at your gaskets somewhere which are forward of the O2 sensor giving them a super lean reading and the car dumps a ton of fuel in.
<shrugs>
Old Mar 2, 2003 | 10:45 PM
vader86's Avatar
vader86
:iagree: park it
Old Mar 3, 2003 | 02:47 AM
SHiNoBi LT4
I seeeriously doubt the exhaust could do that. Opti ?? Sounds like its ready to call it quits. :cheers:
Old Mar 3, 2003 | 08:34 AM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: (SHiNoBi LT4)
No way you're gonna pin this one on the opti. If it was going out the exhaust would show rich as the unburned fuel went down the pipes.
My car behaved very much like yours did before I installed my heated O2 sensors, is there a possibility that they are not heating? I had just guessed at a fuse size for the heater circuit on mine. I eventually blew that fuse and the car went right back to running like crap. I would double check all your wiring and make sure that your heated O2's are getting the juice they need. Your drive ability issues sound EXACTLY like what mine was doing. It sputters and bogs, even sounds like crap, feels like it's running on about 4 cylinders. Eventually you just punch it, it does the same for a second and then magically takes off like a bat out of hell.
Old Mar 3, 2003 | 04:10 PM
dscottr's Avatar
dscottr
Default Re: (Nathan Plemons)
Thanks for the input,
I will quit taking out my frustrations by beating on the car. I've got a chip coming in the mail from fastchip. At No charge again, boy those guys are fantastic! Highly recommend, Ed Wright's outfit. I seriously doubt that the chip will fix the problem, seems way more serious than that. But, we'll see.
Old Mar 3, 2003 | 08:56 PM
Ken Lanham's Avatar
Ken Lanham
This is not correct. If you have a MISFIRE, your O2 sensors will show a LEAN condition! Sure, you have unburned fuel going down the exhaust, but OXYGEN sensors dont sense the fuel in the exhaust. The sense the amount of Oxygen. A misfire leaves unburned fuel and unreacted oxygen in the exhaust. It shows up as a lean condition to any oxygen sensor. I have verified this with a wideband too. When wideband tuning, Its a tricky game if you get a misfire. Sometimes you don't know if the engine began missing because of the lean condition, or if the Wideband was just reading lean because an ignition related misfire started. Does that sound like the chicken and the egg dilemna? The Oxygen sensor can only give you an accurate picture of AF ratio if the combustion event took place completely.
Now, I dont' know anything about the optispark, I drive an L98. But, I wanted to help clarify this lean error code a bit. Could be an exhaust leak too.
Old Mar 3, 2003 | 09:11 PM
severe-1's Avatar
severe-1
Default Re: (Ken Lanham)
I drive a L98 so I don't know much about the LT1, but are you replacing the stock pipes? Does the LT1 have some sort of EGR system that is now causing an air leak of some sort. Kinda just throwing ideas here...
To Headers & no cats cause lean condition?
