clarification.....Fuel injector size for 93 LT1 engine
My EPROM stock shows 23.8 lbs for the injector fuel rate. What should it be and why would the STOCK prom code show higher rates for the size difference? Need to know ASAP
thanks
Kitt
Not absolutely sure on the LT1
[Modified by vader86, 8:25 PM 2/28/2003]
Kitt
thanks
Kitt
Most sources have said that the '92 and '93 LT1 motors have 22 lb injectors and '94 to '96 LT1s have 24 lb injectors.
However, Ed Wright (a recognized expert on programming chips) told me personally that the programming in my chip would not change at all if I put '94 LT1 injectors in my '92 LT1 -- he said they are the same.
But, if you go to this site (http://www.partsamerica.com/default.asp?BypassRedirect=True) and set up your vehicles as a '92 and a '94 and look at the part numbers for the injectors for each, you will see different part numbers -- if they are the same, why different part numbers?
Being curious, I actually did an injector leak-down test in my engine with my stock '92 injector and an injector out of a '94, I could not tell the difference in the fuel pressure after each injector was accurately pulsed with the same time, and their static pressures were the same before the pulse -- since the '94 injector is supposed to have about a 10% higher lb-per-hour rating, I expected to see a lower fuel pressure after the single pulse.
Go figure.
Tom Piper
I don't know if this is the answer, but it sounds logical.
Any ideas?????
Tom Piper
86-91 L98 - 22#
92-93 LT1 - 22#
94-96 LT1 - 24#
96 LT4 - 28#
The 23.8 constant could be there since the motors were built and that with the 22# they still were getting too much fuel so tweated the constant which would change fuel delivery across the board. In Fact I am running 30# on my 89 and have the constant set to 33.. I would not worry too much about the difference
kitt
