Balancing a flywheel?
Old Feb 28, 2003 | 11:57 PM
R Cook 92's Avatar
R Cook 92
Default Balancing a flywheel?
How do I balance my flywheel. An imbalanced flywheel forces a transmission rebuild. I had put on a new flywheel when I built the engine and tranny, but I guess it wasn't balanced... Are they balanced from GM, cause that is where I'm getting my new one. and if not, and even if so, how do I go about checking it??? The car is a LT1, 700r4(MD8), thanks
Old Mar 1, 2003 | 12:43 AM
88-406's Avatar
88-406
St. Jude Donor '05
Default Re: Balancing a flywheel? (R Cook 92)
You should be able to look at it and see if any weights are screwed to it. If they aren't there then you may have a problem. Most engine shops can check it out for you.
KM
Old Mar 1, 2003 | 07:01 PM
CFI-EFI's Avatar
CFI-EFI
The 1 piece seal ('86 and up) crank flywheels are not supposed to be balanced to themselves. The 1 piece seal shafts have a smaller bolt pattern than the 2 piece seal shafts. The bolt flange of the 2 piece seal shafts have a small amount of offset weight that can't be duplicated on the 1 piece shafts. Therefore, late flywheels/flexplates, are "unbalanced". If you balance (true balance) your flexplate, you will upset the balance of the engine. Good luck, and...
RACE ON!!!
Old Mar 2, 2003 | 01:02 AM
88-406's Avatar
88-406
St. Jude Donor '05
Default Re: Balancing a flywheel? (CFI-EFI)
I thought dual mass flywheels have external weight attcahed? I've only seen the McLeod DM replacement and it has two extra bolt holes on it so I can transfer the factory weight.
KM
To Balancing a flywheel?
