Optispark Bolts
Old Mar 1, 2003 | 11:19 AM
FSTRNU's Avatar
FSTRNU
Default Optispark Bolts
I cannot find the socket that will take out the optispark top bolts that hold the cover and base together. I have a torx socket set but it will not fit down deep enough to reach the bolt and I cannot find a deepwell socket to dave my life. Where did you guys find one or what did you use to take it apart? Thanks fellas
Old Mar 1, 2003 | 04:33 PM
SouthernSon's Avatar
SouthernSon
Default Re: Optispark Bolts (FSTRNU)
I bought the complete opti since I have read several times that a rebuild is not necessarily gonna hold up. New complete opti is 242.52 for '96 from Jeff.
Old Mar 1, 2003 | 06:20 PM
FSTRNU's Avatar
FSTRNU
Default Re: Optispark Bolts (southern_son)
This is the old one that I took off when I replaced it. I just want to look at the inside and see what it is like and may try and rebuild it if I can so I need to remove the bolts but cant :cry
Old Mar 1, 2003 | 07:02 PM
bogus's Avatar
bogus
those are them wack torx with the pin in them... you need special torx sockets.
I THINK its an E4... I don't know why I remember that.
Old Mar 1, 2003 | 07:14 PM
FSTRNU's Avatar
FSTRNU
Default Re: Optispark Bolts (bogus)
I have torx sockets but none will reach deep enough to get to the top two bolts.
Old Mar 1, 2003 | 07:29 PM
PurpleC4's Avatar
PurpleC4
Cruise-In I Veteran
Cruise-In II Veteran
Currently Corvette-less
I have had mine apart a couple of times. I think that you may be referring to the male torx screws (vs. female). Try this ~ remove one of the TB cover plate bolts and chuck it into a reversing drill. You should be able to use the female head of the TB bolt to remove the male torx on the OptiSpark.
Once you get the OptiSpark apart, you will need a #8 torx for removal of the rotor. I bought mine from Sears Hardware for a $2.99.
~ Purp :thumbs:
Old Mar 1, 2003 | 08:11 PM
FSTRNU's Avatar
FSTRNU
Default Re: Optispark Bolts (PurpleC4)
Purp, you are always full of infinite wisdom! Thanks :cheers:
Old Mar 1, 2003 | 08:21 PM
PurpleC4's Avatar
PurpleC4
Cruise-In I Veteran
FSTRNU )aka FlubyU.........
Hey Buddy. Let me know if this was what you were referring to.
~ Purp :seeya
[Modified by PurpleC4, 6:22 PM 3/1/2003]
Old Mar 1, 2003 | 09:03 PM
FSTRNU's Avatar
FSTRNU
Purp, I swear your an absolute man of genius, worked like a champ! Thanks bro, first rounds are on me. :cheers: :seeya
Old Mar 1, 2003 | 10:26 PM
Strick's Avatar
Strick
This may sound simple, but here is what I did. I bought some torqs head screws from the "Help Section" of AutoZone. I found a 2" bolt with a torqs head that matched the Opti-Spark male heads and they fit right down the two holes you're trying to get in. I double nutted the end of the bolt and used a nut runner to loosen the opti-spark bolts. Works great and doesn't cost a fortune. If you have 50k or more and drove in some rain, wait til you look inside (especially if you are not vented) :bb
SEE YA
Strick
Old Mar 2, 2003 | 01:14 AM
FSTRNU's Avatar
FSTRNU
Default Re: Optispark Bolts (Strick)
I followed Purps advice from above by using a screw from my old throttle body in a drill. They came right out when I opened it up the white gasket seal thingy was all broken and all the contacts on the inside were green. It doesnt look healthy may start looking for a rebuild kit just in case. Thanks for the advice also. :cheers: Zach
Old Mar 2, 2003 | 10:56 AM
PurpleC4's Avatar
PurpleC4
Cruise-In I Veteran
Bummer. That's why I open mine whenever I flush my coolant. I drop the water pump and check the front seal, then I remove the Opti, check the timing cover seal, open the Opti, reseal the gasket, and re-install. After you have done it once or twice you can drop both, flush the coolant, and have it back to gether again in about 2 hours. That's not an unbearable PM when only done every 12 to 18 months.
The upside is that I am not afraid to wash my engine because I know that my Opti is properly sealed. I do use precaution though, and stuff washcloths around the Opti and coil when I power wash. Notice I said washcloths and not plastic. Plastic will deflect water. I want the washcloths to absorb and hold the water.
~ Purp :crazy:
[Modified by PurpleC4, 8:57 AM 3/2/2003]
To Optispark Bolts
