Tail light bulb replacement
Old Mar 1, 2003 | 01:02 PM
lite blue's Avatar
lite blue
St. Jude Donor '12
Default Tail light bulb replacement
OK. How do you replace the outboard ones? The passenger side, specifically.
I've done the inboard ones, not too bad going through the liscense plate area and the gas boot. But I can't quite fit my arm to the outside one, no matter how I try.
Thanks for any help!
Old Mar 1, 2003 | 01:05 PM
bogus's Avatar
bogus
Default Re: Tail light bulb replacement (lite blue)
I think you have to try them from the bottom.
it helps if you have an additional joint between your wrist and elbow.
Old Mar 1, 2003 | 01:06 PM
DougSilver's Avatar
DougSilver
I assume you are talking about the bulb plus housing and that your model is similar to my 95? For bulb only, the red lens can be removed via a couple of screws from the outside. If you are replacing the housing as well, you need to remove the inboard lights first and access the outboard light via the hole in the bumper where the inboard light was.
Old Mar 1, 2003 | 01:13 PM
lite blue's Avatar
lite blue
St. Jude Donor '12
Default Re: Tail light bulb replacement (DougSilver)
Just the bulb. But there are no screws on an '85. I wish there were. You have to go in from the back, somehow.
Old Mar 1, 2003 | 01:25 PM
JCAIRE2's Avatar
JCAIRE2
Default Re: Tail light bulb replacement (bogus)
:iagree: Have a 10 yr old around would help too :D I had to drop my left muffler to get to the drivers-side outboard taillight. PITA! :mad :cuss
Old Mar 1, 2003 | 02:21 PM
DougSilver's Avatar
DougSilver
Could you still just remove the inboard light and then go in through the inboard hole? (This is starting to sound perverse).
Old Mar 2, 2003 | 12:26 AM
70ZZ3 96LT4's Avatar
70ZZ3 96LT4
The way I do it on my 85 is remove the inboard tail light and use this access hole and then remove the outboard bulb from the housing for change out. Haven't had to do this but only one time in 11 years.
Old Mar 4, 2003 | 10:02 AM
wcgray@gis.net's Avatar
wcgray@gis.net
1st Gear
I did it from the bottom
Old Mar 4, 2003 | 11:02 AM
arbee's Avatar
arbee
I just changed this bulb on my '87. You can easily reach the bulb holder with your left hand(lying on your back with your head towards the rearend) The problem I found was after the socket was removed, there was not enough wire to lower it far enough to use two hands to change bulb in socket. I had to feel around for the wire support clip and break it(I know but by this time I was totally chocked.) Socket then comes down far enough to twist out the bulb.
Old Mar 4, 2003 | 02:30 PM
Bill94LT1's Avatar
Bill94LT1
Be sure to use long life replacement bulbs! :)
Old Mar 4, 2003 | 03:46 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Good looking Vette, BTW.
IT helps to be a contortionist.
To Tail light bulb replacement
