wheel spacers
Old Mar 2, 2003 | 07:44 AM
vstol's Avatar
vstol
Default wheel spacers
Anyone using wheel spacers? I am planning on buying 2" spacers from Vette brakes for my rear wheels, any thoughts
Old Mar 2, 2003 | 07:55 AM
Corvette0096's Avatar
Corvette0096
Default Re: wheel spacers (vstol)
I have a set on my car. They are made by Vette brakes and they are top quality.. :yesnod:
Old Mar 2, 2003 | 07:56 AM
edsalinas's Avatar
edsalinas
St. Jude Contributor
I'm using spacers on my '84, only because I went with ZR1 rims (17x11) on all 4 corners and the offset on the rims I bought is really for '89 and newer. If I didn't use spacers, the tires would rub. But the spacers I'm using are 3/4 inch thick, I can't imagine 2" spacers ! ! ! Your tires are going to stick out past the wheel wells quite a bit. ? ? ? :steering:
[Modified by edsalinas, 5:58 AM 3/2/2003]
Old Mar 3, 2003 | 09:07 AM
atotalnincompoop's Avatar
atotalnincompoop
Default Re: wheel spacers (edsalinas)
:iagree: what kind of wheels are you running that will require a 2" spacer. sounds scary!! :yesnod:
i hope your not making too much power :cheers:
Old Mar 3, 2003 | 09:51 AM
tuband's Avatar
tuband
Cruise-In I Veteran
Don't skimp on quality when using spacers/adapters. Some are good & some aren't.
VetteBrakes are supposed to be good.
Also check out Skulte.com
You might want to read this thread also
http://forums.corvetteforum.com/zero...501228#5501228
Old Mar 3, 2003 | 07:41 PM
vstol's Avatar
vstol
Default Re: wheel spacers (tuband)
THANKS, I AM BUILDING A 64 GRAND SPORT AND USING THE 96 SUSPENSION. I NEED TO BRING THE TIRES OUT ABOUT AN 1 1/2 TO FLUSH THE WHEEL WHEELS.
Old Mar 4, 2003 | 11:04 AM
ROME's Avatar
ROME
Just make sure to check the full travel of your suspension in the rear ( a good time to befriend that 350lb neighbor). :D That outer wheel well lip can be very unforgiving to your tires unless you plan on jacking the rear end up a few inches.
Old Mar 4, 2003 | 01:24 PM
SHiNoBi LT4's Avatar
SHiNoBi LT4
Default Re: wheel spacers (ROME)
check out DRM's website too. i use the CNC machined Billet aluminum spacers. Absolutely top notch quality. :cheers: 177 mph and no issues.
To wheel spacers
