Soon I will be reinstalling my LT4 cylinder heads and figured I would take a pole of various compression ratios folks are running on the street (pump gas).
I know the stock LT4 ratio is 10.8 so this is geared toward the modified LT1/4 type engines...
Mine is 11.54, I actually calculated all of the crevice volume's Etc...
No problems at all, and I haven't seen any odd/high knock counts on my Datamaster scans...I've only used 92-93 octane in it though.
I also kept my quench area to a minimum, which help's eliminate detonation.
I'd need to double check my notes but .018 deck height + .029 head gasket, so I ended up with .047 quench height...
To think 10-15 years ago...anything over 10 to 1 would have been race gas territory with iron heads and carbs, etc!
I may even try for something closer to 12 to 1 when the new shortblock is assembled...will have to see how this cr works on the roadcourse, etc first though...
