Quick advice needed on L98 idle
Steves 84 is bringing his new (to him) 87 vert by the house. He's having problems with it stalling at idle.
Any hints?
Here is the set procedure for the min. idle speed, if you don't have a scan tool you will have to estimate on where you are setting it but you should be able to get close, and where it says to enter "field service mode" that is the same as jumping A+B on the ALDL :thumbs: This procedure is for and '89 but I do believe it is the same on an '87.
{Quote}
Idle Speed
A base idle adjustment is not normally required and should not be performed unless the base idle stop screw had inadvertently been misadjusted during servicing. On replacement throttle bodies, the idle stop screw is not adjusted and is not covered with a plug.
NOTE: If the minimum idle speed is adjusted too high, the IAC pintle will constantly seat in the throttle body, and may cause damage to the IAC valve. If the minimum idle speed is adjusted too low, the vehicle may not start in cold weather, or may stall during warm-up.
ADJUSTMENT:
1. Block the drive wheels and apply the parking brake.
2. Connect a scan tool to the ALDL connector.
3. Turn the ignition "ON."
4. Select TPS on the scan tool and adjust the TPS voltage.
5. Select "Field Service Mode" to seat the IAC pintle. After 45 seconds, disconnect the IAC connector and exit the "Field Service Mode."
6. Disconnect the distributor set timing connector.
7. Place the transmission in Park (A/T) or Neutral (M/T). Start the engine and run until operating temperature and closed loop conditions have been met.
8. Select "Engine RPM" on the scan tool.
9. Adjust idle speed if not within specifications.
10. Turn the ignition "OFF."
11. Connect IAC and set timing connectors.
12. Turn ignition "ON" and recheck TPS voltage.
13. Reset the IAC pintle position by doing the following:
• Depress the accelerator pedal slightly, start and run the engine for five seconds.
• Turn the ignition "OFF" for ten seconds, then start the engine and check for proper idle operation.
14. Disconnect the scan tool.
{/Quote}
[Modified by VetBoy89, 3:40 PM 3/3/2003]
