suspension noise when going over bumps
Old Mar 4, 2003 | 12:06 AM
eric_daniel's Avatar
eric_daniel
Default suspension noise when going over bumps
my 85 makes a horrible "creaking/clanking" noise under the passenger fender when you go over bumps or over speed bumps slowly any kind of firm hard pressure that is placed on the front tires will make it make this sound. It sounds like something is loose. Anyone had any problems with this????
Thanx
Eric
Old Mar 4, 2003 | 12:09 AM
vader86's Avatar
vader86
Default Re: suspension noise when going over bumps (eric_daniel)
sounds like the sway bar bushings are done
Old Mar 4, 2003 | 12:28 AM
corvette8585's Avatar
corvette8585
:iagree:
My 85 is also starting to do the same thing. Far as I have been told it's the bushings in the control arms, or sway bar, or both. Check into getting a bushing kit from someone like Mid America Designs or someone who you get your parts from. These kits are typically cheap. Just decide if you want stock rubber bushings, graphite bushings, or urethane bushings.
Old Mar 4, 2003 | 01:13 AM
Frizlefrak's Avatar
Frizlefrak
Default Re: suspension noise when going over bumps (vader86)
Sway bar bushings. I have the exact same creak/groan, and am getting ready to put new bushings in. Take the sway bar off, back the car out into the street and see if the noise goes away. Bet it does.
Old Mar 4, 2003 | 01:21 PM
Iroc's Avatar
Iroc
Default Re: suspension noise when going over bumps (Frizlefrak)
:withstupid: Same thing with my '85 and its those old rubber bushings. I hear it so much around here (horrible roads) that I won't be phased when I finally put in the poly bushings and they start making noise. :D
Old Mar 4, 2003 | 01:38 PM
John Row's Avatar
John Row
Default Re: suspension noise when going over bumps (Iroc)
:withstupid:
Get all the bushings replaced. It'll make an unbelievable difference in your handling.
Poly or Graphite will both start to make that old sound after about a year. I just learned to live with it and grin around corners.
Old Mar 4, 2003 | 09:08 PM
eric_daniel
Default Re: suspension noise when going over bumps (John Row)
When you say "a kit" what do you mean? I looked at the corvette forum mall and saw the sway arm bushings and it had the different sizes. from like 22-30 mm. I've only had my vette about a year and am still learing alot. What is the best type to get? poly or graphite or rubber? What are the differences in size and which is the best to get? just let me know what you'd do!!!
Thank you guys for all of your help!!!!!!!! :confused:
Old Mar 4, 2003 | 09:18 PM
Iroc's Avatar
Iroc
This page won't link correctly to the actual product but if you go here
http://www.vettebrakes.com/
and do a product search for "sway bar"
Category - Suspension Components
Model - C-4 Corvette
then search it will bring up their poly bushing selections.
These are the ones i'm going to use.
Now all you have to do is figure out what size your sway bars are.
Old Mar 4, 2003 | 09:22 PM
84FromHell's Avatar
84FromHell
It could be any of the things previously mentioned, but when I had the problem with my 84 it was the front spring. The previous owner had let a oil leak go so long it deteriorated the rubber mounting block.
I hope it's your sway bar bushings :D
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Mine never squeaked until I lowered it.
My synopsis is that it's now riding on a different part of the control arm bushings, and they've come unseated and slide around.
If you guys say the poly squeaks after a year, I'd be inclined to go with rubber instead. Cheaper, and goes longer without squeaking, despite cracking sooner and not being as stiff. :yesnod:
Old Mar 4, 2003 | 09:44 PM
VetteNoob's Avatar
VetteNoob
heard the PST kits are pretty nice.
http://www.p-s-t.com
Old Mar 4, 2003 | 09:54 PM
2012 coupe's Avatar
2012 coupe
Default Re: suspension noise when going over bumps (VetteNoob)
I have the PST's in both the front and back of mine for about 4 years now. They squeak going over speed bumps when it is cold outside. Around 35-40 degrees. Other wise they are fine. The front sway bar has fittings on them. I bought the black type.
:flag
Old Mar 4, 2003 | 09:55 PM
eric_daniel
Thanks again for all of your help!!!! :party:
Old Mar 4, 2003 | 11:36 PM
BBA's Avatar
BBA
I just had a shock absorber squeeze it's lower mount rubber bushing out of place yesterday...and it made a knock clank over bumps too...so look for that as well.
To suspension noise when going over bumps
