Hood Weight
Old Mar 4, 2003 | 09:12 AM
arbee's Avatar
arbee
Default Hood Weight
Can somebody please tell me how much weight there should be on the hood? I don't know if my assist rams are shot or not but while bent over the engine last night, the thought occured to me that if that nice little silver buttom on the hood support were to break, I woulldn't be too comfortable. Mine requires about a 30 lb. pull to open the hood.
1987 Red Coupe - stock
Old Mar 4, 2003 | 09:37 AM
c4cruiser's Avatar
c4cruiser
Default Re: Hood Weight (arbee)
The hood support rod on my 87 no longer assists me in putting the hood up or down. I would say it takes about 50lbs to raise or lower mine. It locks in place, but that's all. It's a handful getting it down with dropping hard. The man support rod is an expensive piece to replace! :eek:
The hood is pretty heavy, if it were to drop on you, it would pretty much ruin your day....
[Modified by c4cruiser, 6:39 AM 3/4/2003]
Old Mar 4, 2003 | 09:58 AM
BADMUDE's Avatar
BADMUDE
Default Re: Hood Weight (c4cruiser)
:iagree:
Mine is the same....I really noticed it when I raised the hood on a buddies 96...it was so easy....
I need to get some new ones...
Old Mar 4, 2003 | 04:03 PM
Wheelman's Avatar
Wheelman
Mine has the same problem, i even had the hood fall on me before......that really hurt. Mine is missing the small support and it is as expensive as the big one is. :rolleyes:
Old Mar 4, 2003 | 06:35 PM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: Hood Weight (Wheelman)
i just had mine off i would guess more than 50 lbs probally closer to 65lbs :cheers:
Old Mar 4, 2003 | 07:00 PM
Jim-K's Avatar
Jim-K
Mine takes about no effort at all. Not even 5 lbs I'd say.
Old Mar 4, 2003 | 07:20 PM
87SAM's Avatar
87SAM
Default Re: Hood Weight (BADMUDE)
My was missing one of the two small struts, I bought 2 new ones (around $20 per) and I couldn't tell a difference :(
Old Mar 4, 2003 | 07:23 PM
Jim-K's Avatar
Jim-K
Default Re: Hood Weight (87SAM)
Maybe those aren't the ones that do it. Theres also another long one.
Old Mar 4, 2003 | 09:36 PM
mash557's Avatar
mash557
I just replaced the two struts on mine with ones from Napa. Was very heavy up and down, now the scissor strut doesn't hold any weight, the struts keep is topped out. Cost - about $35.00 for both.
Old Mar 4, 2003 | 09:49 PM
CMYC4GO's Avatar
CMYC4GO
Default Re: Hood Weight (mash557)
Heavy is right! At LEAST 50 lbs. :chevy
Old Mar 5, 2003 | 02:03 AM
86Moon's Avatar
86Moon
Thanks! I had no idea the hood wasn't supposed to weigh a ton :crazy: . I think I can afford $35 at Napa to save me and the hood :cheers: .
Old Mar 5, 2003 | 08:45 AM
87SAM's Avatar
87SAM
Default Re: Hood Weight (Jim-K)
Could well be wrong here :bb but I think some time after 87 they started using the longer struts. Those short ones don't stand a chance.
Old Mar 5, 2003 | 12:12 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
What are the NAPA part numbers for the two short hood assist cylinders?
I need tnem also.
Old Mar 5, 2003 | 12:28 PM
c4cruiser's Avatar
c4cruiser
Default Re: Hood Weight (VetNutJim)
Please, post thoose part #'s. I think I'll replace the ones on my 87.
I think the change to the single gas-charged rod was done in 91. My 92 doesn't have the two small ones, and a buddy upgraded his 90 ZR-1 to the single strut.
Old Mar 5, 2003 | 12:37 PM
Jim-K's Avatar
Jim-K
You're right, I wasn't sure of the year of the change, but my 86 hood weighed a ton. Used to make me shudder of the thought of it falling on me. :eek:
Old Mar 5, 2003 | 09:26 PM
mash557's Avatar
mash557
For my 86 the Napa part number is 819-5311, two required. They were 17.99 each plus tax.
Also if you have weak later large struts, talk to Jeff Kopp. I will probably get the later model hood prop hardware from him after I get this thing back together.
[Modified by mash557, 8:27 PM 3/5/2003]
Old Mar 5, 2003 | 10:40 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
If it fell on you, it'd definitely fluck you up and maybe break the hood. I get pretty worried if I have to work on the car outside on windy days.
Old Mar 6, 2003 | 07:11 AM
BADMUDE's Avatar
BADMUDE
Good Info....thanks! Going by at lunch today....
To Hood Weight
