90 EGR Routing Question
Old Mar 4, 2003 | 04:09 PM
Dale1990's Avatar
Dale1990
St. Jude Donor '15
Default 90 EGR Routing Question
I am in the process of replacing my EGR Solenoid (see pic) and can't figure out which vacuum lines go where. My emissions sticker is not very clear and the melted mass of plastic that was my EGR system is not too helpful either.
I'm pretty sure one goes to the fitting on the bottom of the TB and the other goes to the EGR valve. But which is which?
Thanks!!
Dale
Old Mar 4, 2003 | 07:06 PM
AS84's Avatar
AS84
Default Re: 90 EGR Routing Question (Professor)
on my 90 there is a rubber connector that contains both of the vacuum fittings for the sensor. There is only one way for it to go on. I believe the right side goes to the egr itself. As far as the tb vacuum connection it comes from the left side of the radiator (possible from the charcoal canister) on mine.
