Water pump
Old Mar 4, 2003 | 04:33 PM
drduppa's Avatar
drduppa
5th Gear
Default Water pump
My 1996 LT4 Water pump has started to leak. I only have 16,000 on this vehicle. What is the real cause. I know that we have addressed this issue before in th Forum, But need to hear it again. If I decide to let it go awhile will I Be asking for problems (like blowing out the rear seal) :confused:
Old Mar 4, 2003 | 04:41 PM
STL94LT1's Avatar
STL94LT1
Default Re: Water pump (drduppa)
The water pump on my LT1 started to leak out the weep hole at 12,000 miles.
By driving your car with a leaking water pump you are risking damage to the opti spark.
Old Mar 4, 2003 | 04:48 PM
Strick's Avatar
Strick
Default Re: Water pump (STL94LT1)
Is there a better coolant pump out there on the aftermarket?
Strick
Old Mar 4, 2003 | 04:51 PM
STL94LT1's Avatar
STL94LT1
Default Re: Water pump (Strick)
I haven't found an aftermarket water pump for the LT1/4. But, you can attatch a Meziere electric water pump to your stock housing and eliminate any weep hole leaking.
Old Mar 4, 2003 | 05:02 PM
Strick's Avatar
Strick
Is this what you did?
Old Mar 4, 2003 | 05:04 PM
STL94LT1's Avatar
STL94LT1
Yes, and I really like the way the car performs with the Meziere.
Old Mar 4, 2003 | 05:09 PM
Strick's Avatar
Strick
Okay, lets get serious. How much did it cost, where did you get it, and does it cool as well as the original?
Strick
To Water pump
