Dead Horns
Old Mar 4, 2003 | 06:53 PM
Dougs 90's Avatar
Dougs 90
Default Dead Horns
I have a 1990 C4 with dead horns, I have installed new horns, and checked the fuze. Any ideas?
TIA
Old Mar 4, 2003 | 07:19 PM
no_radio's Avatar
no_radio
Default Re: Dead Horns (bkdaaa)
I think the buttons under the steering wheel "skin" can break. This was a problem on my '96, and the horns also had gone bad. Everything works now, but I had the dealer do the steering wheel part due to the airbag.
Jeff
Old Mar 4, 2003 | 09:03 PM
JCAIRE2's Avatar
JCAIRE2
Default Re: Dead Horns (no_radio)
Which fuse did you check? There is one behind the driver information center in the center of the dash. It is for the security system, but if it blows, your horns won't work. I replaced mine, and had horns. Does your security light in the dash light up when you lock the door, but before you close it?
J
Old Mar 4, 2003 | 11:19 PM
jfb's Avatar
jfb
Find your horn relay and ground the wire that goes to your horn button. This will make the relay close and the horns should get 12v and operate. If they blow, then your horn button is not grounding when depressed. Either the horn button is defective or its ground wire doesn't go to ground.
Also, the theft fuse (powers the horn) gets its power from a fusible link connected to the battery and if 12v is not on the fuse terminals, then your fusible link has been blown and needs replacement.
[Modified by jfb, 10:21 PM 3/4/2003]
Old Mar 5, 2003 | 08:20 AM
Wildride's Avatar
Wildride
Cruise-In II Veteran
Apparently horn problems are very common on the C-4 and in particular with the 1990. There have been many posts on the subject over the years.
I will try to walk you through this, but it is being done from memory so please bear with me. What is mentioned here is mainly specific to the 1990 or later C-4. Prior to 1990 a different design was used.
I am assuming that you have checked and cleaned the electrical connections at the horns themselves and checked the fuses.
Many people have reported corrosion in the horns themselves. The cure is either replacement or squirting penetrating oil or WD-40 into the horn. I have never had to try that so I can’t vouch for its effectiveness.
The operation of the horn relay can be checked with 98% reliability by activating the VATS (Vehicle Anti Theft System) following these steps:
1. Roll down the windows.
2. Turn the ignition “Off”.
3. Exit the car.
4. Lock the doors.
5. Reach in through the window and “Unlock the Door”
6. Attempt to start the car.
If when you try to start the car and the horn goes off, the horn relay is okay. To reset the alarm and to be able to start the car, lock the door with the key and then unlock it with the key. The horn relay is a DPST relay that works either from the horn buttons or the security system.
There are several problems I have found that seem to come up with the horn buttons,
1. The Buttons themselves are made of a plastic that seems to deteriorate over time. This plus the normal (and abnormal) pressing on the buttons causes a little "nipple" inside of them to break. This nipple's purpose is to press down on the brass contacts underneath it and complete the circuit. No nipple = no contact = no horn.
2. There is a wire (one only) that goes between the brass contacts and the hub of the steering wheel. At the end of this wire is attached a plastic spring loaded male bayonet fitting that is inserted into a female socket in the steering wheel hub and twisted into place to hold it. This plastic bayonet fitting and/or its socket will also give up after time and separate causing an intermittent contact or no contact.
Solutions:
1. The horn buttons are available from GM for about $6.95 each. PN
12506007 and 12500608. There are two ways to remove them from the steering wheel.
A. Using a dull thin blade slide it along the hub side of the button feeling carefully for the catch that latches the button to the wheel. There are two on each side-total four, you only have to find and release two on one side of the button.
The top one is about 1/2-3/4' down from the top of the button and the bottom one is about 1/2-3/4" up from the bottom of the button. When you locate each catch, push in (toward the center of the button) gently on it while lifting the button. You have to do this twice-top and bottom on one side. The button should then pop off.
I have mine discretely marked so the catches are easy to find. You may want to do this to them after they are off.
B. The second way means removing the airbag. Disconnect the battery. Pull the fuse controlling the airbag. At the rear of the steering wheel spokes are imbeded two torx screws (size T-27 ). Unscrew these two screws and then GENTLY lift off the airbag. I advise being off to one side of the steering wheel while doing this as an improperly handled airbag can be dangerous. (These things are shipped all over the country without problem but I would rather be cautious). BE SURE THERE IS NO ELECTRICAL POWER AVAILABLE!!!!
After the airbag is removed, the buttons, contacts and wires are easily accessible.
2. If the wire/bayonet socket is defective the solution is a little more involved. The airbag must be removed as above to get to the wire.
To the best of my knowledge replacement sockets are not available and the GM solution is to replace the steering wheel hub assembly. VERY EXPENSIVE and a lot of labor.
But there is hope. Using a piece of stiff plastic (1/16" Plexiglas sheet works fine or cut up an old AOL CD) cut it into a U shaped piece that fits flat into the hub around the hub retaining bolt and with a very narrow slot that the horn wire was fed (but not wide enough slot to allow the bayonet socket to come through) over the socket. This piece will hold the bayonet socket in place. The plastic piece is held in place by a very short bolt (1/2") that is screwed into one of the bolt holes that are used for a steering wheel puller. DO NOT use a long bolt as it may hit the internals underneath the hub causing short or other problems.
I hope the description makes sense. A picture (if I had one) would make it very clear.
It seems that many people have problems with the horns on their C-4. I hope this helps resolve some of the problems.
Old Mar 5, 2003 | 09:32 PM
Dougs 90's Avatar
Dougs 90
Default Thanks To All of YOU!!!!!
Just wanna say thanks, I am going to tear into this this weekend and see what is up. I appreciate the info big time!
Doug
:thumbs:
Old Mar 6, 2003 | 11:19 AM
KYVette90's Avatar
KYVette90
Default Re: Thanks To All of YOU!!!!! (bkdaaa)
Hey Doug. I have already checked the buttons and contacts and they were working alright. The contact for the single ground wire under the steering wheel looked good too. The security light blinks on the dash like it's supposed to. When the alarm is tripped I could hear the relay clicking like it was supposed to. I know, for a fact, that both horns had gone bad because of internal corrosion. So I'd say either the relay has gone bad, or there is a bad ground wire in the column itself. Airbag removal isn't a big deal. Unhook the pos side of the batt , remove the airbag fuse, wait about 30 minutes, just incase, then unscrew the two philips screws in the back of the steering wheel. The airbag will come out and unplug it. Set it in an out of the way spot. Good luck with those horns. :cheers:
To Dead Horns
