STARTER WIRE QUESTION
Old Mar 5, 2003 | 02:45 AM
PMARTINEZ92126's Avatar
PMARTINEZ92126
Default STARTER WIRE QUESTION
starter has three terminals. I know what hooks up to the big one but I forgot if the smaller wire goes to the smaller connection on the terminal facing the engine block or the one facing the other direction. :crazy:
Old Mar 5, 2003 | 09:13 PM
jfb's Avatar
jfb
Default Re: STARTER WIRE QUESTION (PMARTINEZ92126)
The starter motor only has two electrical connections. A large bolt which the battery cable connects to and and a smaller bolt that the starter solenoid wire connects to.
Old Mar 5, 2003 | 09:25 PM
don hall's Avatar
don hall
You may have a starter that has three posts: large post for the batt. , ignition terminal switch, and a starter motor strap. The post should be of unequal sizes to aid in reinstalling the wires.
Old Mar 5, 2003 | 09:32 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: STARTER WIRE QUESTION (jfb)
If it has three, connect your small wire to the stud marked "S" on the solenoid. I think this is the bigger of the two. The other small terminal is a vestage from the "olden days" (points) when the resister wire to the coil was bypassed to provide a full 12 volts to the ignition during cranking, and therefore a slightly hotter spark during cranking. Good luck, and...
RACE ON!!!
To STARTER WIRE QUESTION
