Bypass?
Old Mar 5, 2003 | 07:55 AM
CMYC4GO's Avatar
CMYC4GO
Default Bypass?
I keep hearing stuff on here about "bypassing" the throttle body. Just exactly what is that, and what are it's benifits???
Old Mar 5, 2003 | 08:41 AM
Drewdog's Avatar
Drewdog
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Bypass? (Klimper)
Bypassing the TB is good for about 5-7hp or so. Hot air is blown into the throttle body to keep it from freezing up in winter conditions, but it isn't necessary, so all it's really doing is hurting performance (cold air=hp) It took me 10 min to do and cost me around 50 cents to do , I used this site
http://www.westol.com/~brettd/corvette/tbcool.html
vader86's Avatar
vader86
GM designed the coolant to run thru the TB to keep the plates from freezing in extreme cold. Only problem is that it has to get damned cold for that to happen(like alaska, montana-type cold), and it could only happen if you were creeping along, once the engine warms up this coolant does nothing but heat up the air coming into the plenum, robbing you of a couple hp.
All you do is disconnect the hoses coming in and out of the TB, and mate them together with a piece of pipe and two clamps.
Old Mar 5, 2003 | 09:38 AM
Steel Blue 91's Avatar
Steel Blue 91
The object is to eliminate the TB from the coolant flow, thus not heating the air as it passes through. The theory is that a cooler air chagre is a denser one.
Old Mar 5, 2003 | 09:41 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I got a U shaped piece of heater hose at Auto Zone, cut one end to lenght, removed the heater hose & short stub from the TB, connected the new piece directly between the water pump fitting and the heater. I cut the heater hose so that the coupling was behind and below the A/C compressor and out of sight for a neat job.
You can get two rubber vacuum hose nipples to fit over the TB coolant fittings to dress up the job.
As mentioned the TB now runs much cooler than when coolant was running through it.
Old Mar 5, 2003 | 10:25 AM
Strick's Avatar
Strick
They designed and built these Vettes to fly and it gets cold at altitude! That's why the throttle body is heated; to stop icing. I keep mine on the ground, so I did the bypass. Sounds like a heart operation. :lol:
Strick
To Bypass?
