Vibrating steering wheel
Old Mar 5, 2003 | 10:50 AM
redvetteC4's Avatar
redvetteC4
Default Vibrating steering wheel
What would cause the steering wheel to vibrate a considerable amount. I am not really worried just curious. Is it an easy fix?
Old Mar 5, 2003 | 11:52 AM
Steel Blue 91's Avatar
Steel Blue 91
Default Re: Vibrating steering wheel (redvetteC4)
Front wheel balance would be my guess.
Old Mar 5, 2003 | 12:00 PM
BBA's Avatar
BBA
It's usually an out of round tire/wheel combo.
Move one of the front wheels to the back and drive it if the vibration goes away you found the bad front tire...the one you moved to the back. If the vibration stays, move the other to the back and recheck. That will tell you which tire it is, then go to a balance shop that has a hunter tire optimizing balancer and have the suspect tire optimized.
If the wheel is out of round, there is a shop you can send it to to have it fixed...I just don't know the contact infor right now, but I am sure some one else here will post contact info.
[Modified by BBA, 12:03 PM 3/5/2003]
Old Mar 5, 2003 | 01:39 PM
SHiNoBi LT4's Avatar
SHiNoBi LT4
Default Re: Vibrating steering wheel (BBA)
if its with the roof off/down then its cowl shake. The obvious would be tire/wheel balance though.
Old Mar 5, 2003 | 02:00 PM
CMYC4GO's Avatar
CMYC4GO
Had the same problem, had tires balanced, and no change, Went and got a balance called "Road Force" Found out I had a tire slightly out of round, had it moved to the back, and shazam! The vibration left :thumbs:
Old Mar 6, 2003 | 01:54 AM
Frizlefrak's Avatar
Frizlefrak
As mentioned, tire and/or wheel out of balance, worn suspension or steering component, tire with a tread separation etc. When I first got my Vette, it had a bad vibration that a new set of shocks cured ( the old ones were really whipped). Start with a wheel balance and rotation, and if it persists, start looking for parts at the end of their service life.
Old Mar 6, 2003 | 02:23 AM
CanadaVette's Avatar
CanadaVette
Hit a good pothole lately?
Old Mar 6, 2003 | 10:15 AM
92LT1Roadster's Avatar
92LT1Roadster
Default Re: Vibrating steering wheel (CanadaVette)
:yesnod: Balance you tires
Old Mar 6, 2003 | 03:00 PM
ered95's Avatar
ered95
Default Re: Vibrating steering wheel (92LT1Roadster)
My 95 used to vibrate from 70 mph +. New shocks cured my problem. :cheers:
Old Mar 6, 2003 | 04:11 PM
86_RedRider's Avatar
86_RedRider
Cruise-In V Veteran
St. Jude Contributor '03 & '05
Default Re: Vibrating steering wheel (ered95)
how difficult is it to replace the shocks on a c4? does anyone recommend any certain types?
Old Mar 6, 2003 | 04:21 PM
redvetteC4's Avatar
redvetteC4
Default Re: Vibrating steering wheel (86_RedRider)
With some of the crummy roads around here I have unfortunately hit some potholes. Usually its not that bad but there have been a few occasions where I could really feel it...hmm...come to think of it before hitting those potholes I don't remember it doing this. :(
To Vibrating steering wheel
