starting
Old Mar 5, 2003 | 11:58 AM
aldo802's Avatar
aldo802
Default starting
I just went out to start my car and it doesn't turn over!! I took the battery cables off and they look cleand and everythings seems to work. When I turn the key there isn't any click sounds like a dead battery would make :confused:
Old Mar 5, 2003 | 12:24 PM
ShawnZR-1's Avatar
ShawnZR-1
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'05-'06-'10-'11-'12
Default Re: starting (aldo802)
Do any of the lights work? Headlights?
Old Mar 5, 2003 | 01:06 PM
aldo802's Avatar
aldo802
Default Re: starting (ShawnZR-1)
Yes everything works fine! :confused:
Old Mar 5, 2003 | 03:10 PM
kittmaster's Avatar
kittmaster
Vats?
Old Mar 5, 2003 | 03:15 PM
aldo802's Avatar
aldo802
Default Re: starting (kittmaster)
What's VATS???????? :confused:
Old Mar 5, 2003 | 03:18 PM
VetBoy89's Avatar
VetBoy89
Vehicle Anti-Theft System. Wait about 5-10 minutes then try it again, if it still doesn't work try using your spare key. Sometimes the pellet in your key gets dirty or worn down.
Old Mar 5, 2003 | 03:21 PM
aldo802's Avatar
aldo802
Default Re: starting (VetBoy89)
I put in a by- pass so I wouldn't have to go through that. I use a regular key but i did try my stock key too!!
Old Mar 5, 2003 | 03:23 PM
aldo802's Avatar
aldo802
I went out there yesterday and it didn't start then either!!
Old Mar 5, 2003 | 03:29 PM
VetteNoob's Avatar
VetteNoob
stoopid question, i know, but is the battery good? if so, the starter could have gone kaput.
Old Mar 5, 2003 | 03:39 PM
aldo802's Avatar
aldo802
Default Re: starting (VetteNoob)
Yea, the battery is good!! i put it in 2 yrs ago a interstate!!! Maybe the starter, just can't get under it at the moment with all the snow we had and i have to find away to jack it up!! I made ramps but if i can't start it i can't drive on them! Man, ur car is the same color is mine!!! I have a 86 coupe with a ZR-1 tail!! I can't figure how to put pictures on here either!!! :confused:
Old Mar 5, 2003 | 03:48 PM
jimswhite92's Avatar
jimswhite92
There are several items in the starter circuit:
Ignition switch
VATS
Starter enable relay (In center of dash)
Gear selector switch - Automatic - Base of shaft lever
Clutch switch - manual - top of clutch pedal bracket
Starter
Battery cable going to starter
Power to ignition switch
Volt meter and start tracing 12V
Got a wiring diagram if you need
Jim
Old Mar 5, 2003 | 04:01 PM
ZZZASY's Avatar
ZZZASY
Default Re: starting (jimswhite92)
When mine did the exact same thing you are talking about, it was my clutch switch. Someone on the forum told me to try the clutch switch, so I ordered one because they were cheap over the internet. Well, the switch was cheap, but it was a lot of work to get to it. Replaced the switch; same problem. Took it to the dealership; found out I had been sold a bad switch. The service manager told me to just cut the wires and tie them together instead of going through the trouble to replace the switch. Did that and everything worked fine. Wish I had done that from the beginning instead of going through all the trouble to replace the switch. As a matter of fact, a forum member had already said bypass the switch, but because of the price, I bought a new one.
ZZZASY
'96 LT4
Old Mar 6, 2003 | 10:07 AM
Steel Blue 91's Avatar
Steel Blue 91
Check fuses also. I had the cluster fuse go and it gave the same symptoms.
To starting
