Hwy.Mode Fuel/Spark
Old Mar 5, 2003 | 11:23 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Default Hwy.Mode Fuel/Spark
This is in the CONSTANTS table of TunerCats.
What is it?????
MIN Coolant Temperature For Highway Spark Advance.....151.3 c
MIN Vehicle Speed For Highway Mode Fuel.......................255 mph.
Whatever it is I don't think I can get it before my engine melts down.
And it's pretty hard to find a highway you can run 255mph on these days.
What are these parameters, boys and girls?????
Old Mar 6, 2003 | 02:28 AM
drive it's Avatar
drive it
Default Re: Hwy.Mode Fuel/Spark (VetNutJim)
Hwy mode spark and fuel is in the tdf from GM-however the factory left it disabled by setting those parameters. As to why? Anybody????
I have enabled mine by decreasing the limits to where I wanted it to engage-and it did help a bit with mileage.
Note all the other parameters to enable it-map rpm etc. and also f/a vs map-just have to decide based on where you "hit cruise" conditions.
Old Mar 6, 2003 | 03:25 AM
ol,RJ's Avatar
ol,RJ
Default Re: Hwy.Mode Fuel/Spark (drive it)
you can find some info on the "highway mode fuel & spark" on the Thirdgen site, just do a search in the "DIY prom section".
if you decide to turn it on be cautious (don't want to lean it out too much).
from one post I read on the thirdgen site they recommended not going over 15.2 to 1 on the air fuel ratio to stay safe.
RJ
Old Mar 6, 2003 | 11:35 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Default Re: Hwy.Mode Fuel/Spark (ol,RJ)
Hmmm. I don't know boys and girls.
If the GM Powertrain was afraid to fool with it.... maybe I better leave it alone also.:nonod:
Maybe I'd better go back to the fans or something simple. :steering:
Old Mar 6, 2003 | 11:58 PM
drive it's Avatar
drive it
Lots of folks have used it; don't worry-just don't get carried away.... :cheers:
Old Mar 7, 2003 | 09:11 PM
Cooter's Avatar
Cooter
GM spent a lot of time and effort (also known as money) to develop highway fuel and spark mode. It was the EPA that forced them to disable it. It is a way to cheat the fuel mileage numbers to make them better, but while running lean, combustion temps go up and so do NoX emissions and the feds said :nono:
To Hwy.Mode Fuel/Spark
